Suggestion from me for a future [cli-api]
would be better if add more permission for cli-api
example can run this command in cli-api
v-list-sys-info
because recently a list permission for cli-api its still less than cli available in CLI Reference | Hestia Control Panel
You can create your own cli permissions if you want or add the access key via terminal so it can even run every command
I see thanks
