as i can see
fresh installation not activating swap-file
should i added it manual ?
swap is not directly related to hestia, more to the OS itself. If you have enough ram, swap isnt directly needed, but I still suggest to make a small partition for it.
thankyou so that is optional and will not make trouble if i use it?
