Template not adding correclty
When a user is created with website the template i added on the ftp is added but the directories like /dashboard are empty and should have content in, how to fix
What folder did you upload it to?
i uploaded it to “”/usr/local/hestia/data/templates/web/skel/public_html""
@eris
@sahsanu any help please
What kind of template are you trying to add?
For web templates is here /usr/local/hestia/data/templates/web/nginx/php-fpm
For php templates /usr/local/hestia/data/templates/web/php-fpm
im adding php files and folders with more php files
It doesn’t help pinging me or any other moderators. We do our work for free and we don’t make any money out of Hestia at the moment…
okay sorry, i can still get help?
ls -la /usr/local/hestia/data/templates/web/skel/public_html/dashboard/ | head
root@alpha-e04909c76b:~# ls -la /usr/local/hestia/data/templates/web/skel/public_html/dashboard/ | head
total 104
drwsrwsrwt 18 root root  4096 Aug  2 10:28 .
drwxr-xr-x 12 root root  4096 Aug  2 10:28 ..
-rwxrwxrwt  1 root root   778 Jul 30 16:12 .htaccess
drwsrwsrwt  2 root root  4096 Aug  2 10:28 account
drwsrwsrwt  2 root root  4096 Aug  2 10:28 api
drwsrwsrwt  2 root root  4096 Aug  2 10:28 clan
drwsrwsrwt  2 root root  4096 Aug  2 10:28 clans
drwsrwsrwt  2 root root  4096 Aug  2 10:28 download
drwsrwsrwt  7 root root  4096 Aug  2 10:28 errors
root@alpha-e04909c76b:~#"
Why you changed the perms to have setuid, setgid and sticky bit?
Also, is there a dashboard dir in /home/YourUser/web/YourDomain/public_html/?
the folder adds but theres nothing inside, and i changed perms to see if this could fix issue
I tested it right now and it works as expected:
❯ cd /usr/local/hestia/data/templates/web/skel/public_html
❯ mkdir dashboard
❯ echo file1 > dashboard/file1
❯ echo file2 > dashboard/file2
❯ mkdir dashboard/testdir
❯ echo test > dashboard/testdir/test
❯ ls -lR dashboard
dashboard:
total 12
-rw-r--r-- 1 root root    6 ago  2 15:46 file1
-rw-r--r-- 1 root root    6 ago  2 15:46 file2
drwxr-xr-x 2 root root 4096 ago  2 15:46 testdir
dashboard/testdir:
total 4
-rw-r--r-- 1 root root 5 ago  2 15:46 test
❯ v-add-user testdir '!!SecretPassword!!' [email protected]
❯ v-add-web-domain testdir testdir.example.net
❯ ls -lR /home/testdir/web/testdir.example.net/public_html/dashboard
/home/testdir/web/testdir.example.net/public_html/dashboard:
total 12
-rw-r--r-- 1 testdir testdir    6 ago  2 15:48 file1
-rw-r--r-- 1 testdir testdir    6 ago  2 15:48 file2
drwxr-xr-x 2 testdir testdir 4096 ago  2 15:48 testdir
/home/testdir/web/testdir.example.net/public_html/dashboard/testdir:
total 4
-rw-r--r-- 1 testdir testdir 5 ago  2 15:48 test
When you add a web domain, Hestia executes this copmmand:
user_exec cp -r $WEBTPL/skel/* "$HOMEDIR/$user/web/$domain/" > /dev/null 2>&1
So it is just a cp -r and it should work fine.
i make the account and domain with the API, but the template should add by itself with no error
does bind9 has smth to do?
i created an acc manually with the panel and i have same error, the folders are empty
Are you adding a web domain to that new user?
find /usr/local/hestia/data/templates/web/skel/public_html -type d | xargs chmod 755
find /usr/local/hestia/data/templates/web/skel/public_html -type f | xargs chmod 644
And try to create a new user and add a web domain to that user.
well i found the “fix” on hestia FTP dosnt show up but if you use a FTP client like WINSCP will show the folders content
well nvm on ftp shows but on the website does not
