Hello. Please do not scold me much
Please help me create a web template for a forum on phpbb 3.3.2. What is needed is a template for adding (creating a new package) to HestiaCP.
Hi Grey
What’s your setup? nginx + fpm or apache2 + nginx? For the last one, you would not need any template, htaccess should do the job.
Debian 10 4.19.0-13-amd64 #1 SMP Debian 4.19.160-2 (2020-11-28) x86_64 GNU/Linux. Nginx + php-fpm. Command: bash hst-install.sh -n yes -w yes -o yes -v yes -t no -c no -x yes -z yes -b yes -i yes -m yes -q yes -l ru \ -a no -k no
It’s about the template, where the path is /usr/local/hestia/data/templates/web/nginx/php-fpm
I would like phpbb to work correctly and stably.
I never installed phpbb, but it is probaly easy to resolve:
First of all, you need to copy the default.tpl and default.stp to phpbb.(s)tpl, then adjust the file to the needed nginx blocks. Probaly you could take the sample config from here:
You don’t need to change the php parts, just take them instead the proposed one in the sample config:
Currently, it sounds comlicated, but it’s easy, maybe also a bit a “try and error”, but I’m sure you can do it.
This is my template for phpBB
phpBB.tpl
# phpBB Template #
server {
listen %ip%:%web_port%;
root %docroot%;
access_log /var/log/nginx/domains/%domain%.log combined;
access_log /var/log/nginx/domains/%domain%.bytes bytes;
error_log /var/log/nginx/domains/%domain%.error.log error;
location / {
location ~* ^.+\.(jpeg|jpg|png|webp|gif|bmp|ico|svg|css|js)$ {
expires max;
location ~ [^/]\.php(/|$) {
if (!-f $document_root$fastcgi_script_name) {
return 404;
fastcgi_split_path_info ^(.+\.php)(/.*)$;
fastcgi_pass %backend_lsnr%;
fastcgi_index index.php;
try_files $uri $uri/ /app.php$is_args$args;
# Deny access to internal phpbb files.
location ~ /(config\.php|common\.php|cache|files|images/avatars/upload|includes|(?<!ext/)phpbb(?!\w+)|store|vendor) {
deny all;
# deny was ignored before 0.8.40 for connections over IPv6.
# Use internal directive to prohibit access on older versions.
internal;
location /error/ {
deny all;
return 404;
location /vstats/ {
alias %home%/%user%/web/%domain%/stats/;
location @rewriteapp {
rewrite ^(.*)$ /app.php/$1 last;
# Correctly pass scripts for installer
location /install/ {
try_files $uri $uri/ @rewrite_installapp =404;
# Pass the php scripts to fastcgi server specified in upstream declaration.
location ~ \.php(/|$) {
return 404;
try_files $uri $uri/ /install/app.php$is_args$args =404;
location @rewrite_installapp {
rewrite ^(.*)$ /install/app.php/$1 last;
# Deny access to version control system directories.
location ~ /\.svn|/\.git {
deny all;
internal;
and phpBB.stpl
# phpBB Template #
server {
listen %ip%:%web_ssl_port% ssl http2;
root %sdocroot%;
ssl_certificate %ssl_pem%;
ssl_stapling on;
ssl_stapling_verify on;
location / {
expires max;
return 404;
deny all;
internal;
location /error/ {
deny all;
return 404;
location /vstats/ {
return 404;
deny all;
internal;
proxy_hide_header Upgrade;
