bostic
March 25, 2022, 6:09am
1
Hi, team!
Yesterday and today I get letters to mail:
sudo /usr/local/hestia/bin/v-update-sys-queue restart
sudo: unable to resolve host mydomain.com : Temporary failure in name resolution.
sudo /usr/local/hestia/bin/v-update-sys-rrd
sudo /usr/local/hestia/bin/v-update-sys-queue backup
sudo /usr/local/hestia/bin/v-update-sys-hestia-all
W: Failed to fetch https://apt.hestiacp.com/dists/buster/InRelease Temporary failure resolving ‘apt.hestiacp.com ’
Debian 10.11 Hestia:v1.5.11 Auto update.
What went wrong?
This is due to automatic update?
DNS stopped working on your server, check your dns configuration. The server also may be slow, due to missing lookups.
bostic
March 25, 2022, 8:15am
3
Hey,ScIT
Thanks for the answer, I will check the configuration.
I consult where this DNS configuration is reviewed, since I have the same problem, if you could provide more details I would greatly appreciate it.
eris
April 4, 2022, 5:54pm
5
/etc/resolv.conf
Check if ping google.com works or otherwise check your network configuration
bostic
April 5, 2022, 10:16am
6
Hi! Today I received mistakes again
Check if ping google.com works - WORKS
/etc/resolv.conf - There is no file
Found a file - etc/resoivconf/run/resolv.conf:
nameserver (ip-contabo.com ,my vps )
search invalid
I need to create a file separately in /etc/ ?
Those are the emails that I am receiving, I have already pinged google from my server and it is responding as seen in the screenshot
I appreciate more instructions to solve this problem.
eris
April 5, 2022, 11:36am
8
@AlexMKTD what happens when you run on your server:
nslookup vps.alexhurtadomktd.com
You can also add
127.0.0.1 hostname
to your /etc/hosts file
eris
9
If ping google.com is working it should be fine what happens when you run:
nslookup hostname.com
This is the response I get on my server.
bostic
April 5, 2022, 12:14pm
11
Server: 213.136.95.10
Address: 213.136.95.10#53
Non-authoritative answer:
Address: 144.91.73.12
bostic
April 5, 2022, 12:33pm
12
Maybe a problem on the side contabo ?
