It is possible that some attackers try to steal your information from servpc.cl (eg, passwords, messages or credit cards). More information
NET::ERR_CERT_COMMON_NAME_INVALID
That comes out when you want to enter the Hestia Control Panel for a domain, and be able to manage its options.
for example: servpc.cl:8083.
Can you please help me to solve this problem
eris
January 13, 2023, 1:16pm
#2
Known issue you can only use the hostname if you want to avoid the message. It should not really matter…
Excuse my ignorance, but I don’t understand:
Known issue: You can only use the hostname.
What do you mean by that, what do I tell a client, so that they have access to the control panel and create their email accounts and database?
eris
January 13, 2023, 3:32pm
#4
Tell them that have to use the hostname you setup during the installation…
Sorry, I really don’t understand:
If I put: url: servpc.cl:8083, it gives that error
So what url should it be, if they tell me to use the host name,
The host name is that servpc.cl, or am I wrong?
eris
January 13, 2023, 4:06pm
#6
http://servpcspa.com is the hostname used during the setup so it should be used
