The install script is a bit broken it seems
Trying to install hestiacp on a newly deployed digitalocean vps. Before running the hestia installer i did a system upgrade (apt upgrade), after that i run the script and I get this eror:
Please wait, the installer is now checking for missing dependencies…
[ * ] Installing dependencies…
WARNING: The following packages are already installed
exim4*
It is highly recommended that you remove them before proceeding.
Would you like to remove the conflicting packages? [y/n] y
-bash: y: command not found
[7]+ Stopped bash hst-install.sh
This is the code used during install:
        read -p 'Would you like to remove the conflicting packages? [y/n] ' answer
        if [ "$answer" = 'y' ] || [ "$answer" = 'Y' ]; then
                apt-get -qq purge $conflicts -y
                check_result $? 'apt-get remove failed'
                unset $answer
        else
                check_result 1 "Hestia Control Panel should be installed on a clean server."
        fi
and I can’t see any problem with this code.It is a bit weird.
Anyways, you can use argument --force when executing the install script to avoid that question.
Just run apt remove exim4 …
i did, no help… i had to redeploy the vps.
i just redeployed a vps… launched the script right away and the output is:
Welcome to the Hestia Control Panel installer!
Please wait, the installer is now checking for missing dependencies...
[ * ] Installing dependencies...
root@vps:~#
It seems like it crashes or something happens. its displaying a root prompt right after
EDIT: this is the exact command
bash hst-install.sh --hostname vps --email [email protected] --password kljh342kòl --multiphp yes
Its a debian 12 vps
EDIT2: after waiting 5-10 minutes i tried to run the script again and i am getting this output:
E: Could not get lock /var/lib/dpkg/lock-frontend. It is held by process 3083 (apt-get)
E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), is another process using it?
Error: Package installation failed, check log file for more details.
impossible to install… i just tried to run apt remove exim4* and there is nothing installed… yet hestia installer is telling me:
exim4*
[5]+ Stopped
Try again the installation script but don’t use character ò in password, also, enclose it with single quotes…
that did the trick thank you, maybe you should fix that in those checkbox options on the website.
