HI need help w time out in myadmin
Check also Apache2 config
To import big files you can do 5 things:
- whenever you see the timeout, hit refresh page. Sometimes it eventually finishes the import without noticeable errors (I don’t like it)
- Increase timeout times (I don’t like it)
- split the database into smaller pieces ( mysqlsplitter gets the job done but it is uncomfortable)
- import with mysqldump via command line ( this is the best method)
- if it is WordPress you can also “sudo -u username wp db import database.sql” ( best method for WP)
For a 1mb large it should be no issue
Th…you for help, but my problems from configuratiom. If i use Nginx/fpm-php/Ubuntu 22.04 all good work NO TIME OUT! if change to APACHE+Nginx/fpm-php/Ubuntu 22.04 GET TIME OUT
Then it is a config issue. Do as eris says, change the timeout values
