Hi when I try to setup an email account in thunderbird. I get this error “TLS not available due to temporary reason”, when trying to use starttls on smtp. How can I fix it.
Not enough information to reproduce your problem. There are no known issues with dovecot or exim4 on Thunderbird, I’m using it myself.
I am trying to add an email account, when I force starttls for smtp, I get the error. It is a domain on Hestiacp. If I use no encryption on smtp I can add the account. The same issue was also on vestacp. Hope this enough info.
SMTP with StartTLS:
port: 587
Connection security: STARTTLS
Auth method: Normal Password
SMTP with SSL/TLS:
Port: 465
Connection security: SSL / TLS
@napisok - Try to temporary disable CSF and retry.
I have no such issues with e-mail Exim subsystem.
Can’t find any point that csf is used here?
Edit: Ah sorry, didnt noticed the second post.
tried
disable csf
use smtp as ssl
But I did not work. Have read some place that it should be a settings in exim, but cannot remember there
@napisok have you checked the settings I posted earlier?
yes I did, tried with different port and normal password on windows 10
@napisok - Could you please try to connect from different device / location?
For SMTP diagnosis I can recommend SMTP Console from Socketlabs - saved me tons of time.
