Too many open files despite config adjustments
Screenshot 2023-08-09 at 16.38.24
In the [Service].
As I said in my post, the real change that made it work for me was to raise root’s limit specifically, and test it with ulimit -n as the root user.
Screenshot 2023-08-09 at 16.41.24
I’ve got 395 domains configured. With the changes I documented in this thread
   1030 named
   1139 php-fpm8.
   2110 mariadbd
   7398 nginx
 114563 apache2
All limits are raised and verified same as yours.
This is getting frustrating, also for our users…
Did you put the nginx.conf setting back to 65536?
# Server globals
user                    www-data;
worker_processes        auto;
worker_rlimit_nofile    65535;
yes, same exact lines
I manage 2 servers with 3000 websites on 1 user (not a very good choice on my opinion, but the client want it that way).
I have change the config to log everything on 1 access.log file for nginx and 1 for apache.
Removed the / domain log, remove the byte log format…
This helped a lot…
Issue returned, I am getting clueless…
@Sich can you share your configuration so I can try if it resolves the issue?
The main change that I have done is to log everything at 1 place.
First NGinx :
In the template file (/usr/local/hestia/data/templates/web/nginx), comment the access_log that are setup and add the new one :
#            access_log     /var/log/%web_system%/domains/%domain%.log combined;
#            access_log     /var/log/%web_system%/domains/%domain%.bytes bytes;
             access_log  /var/log/nginx/access.log host;
To be able to see wich vhost in concerned by each log you have to create a logtype. This is in /etc/nginx/nginx.conf :
Add this line :
log_format host '$host $remote_addr - $remote_user [$time_local] "$request" $status $bytes_sent "$http_referer" "$http_user_agent"';
After that on Apache, depend on how you have setup your server about the template file. Same here, disable the default log files and add yours :
#    CustomLog /var/log/%web_system%/domains/%domain%.bytes bytes
#    CustomLog /var/log/%web_system%/domains/%domain%.log combined
#    ErrorLog /var/log/%web_system%/domains/%domain%.error.log
     CustomLog /var/log/apache2/access.log vhost_combined env=!dontlog
The env=!dontlog is to avoid logging all static ressources, usefull when you have a lof of activity. If you do want to log access to static ressources, remove env=!dontlog
Now you have to edit /etc/apache2/apache2.conf
Change the line with vhost_combined to be like that one :
LogFormat "%v %a %l %u %t \"%r\" %>s %O \"%{Referer}i\" \"%{User-Agent}i\"" vhost_combined
mostly change %v:p to %v and %h to %a (if I remember correctly).
Add a new error log format to get the vhost name in the log :
ErrorLogFormat "[%{u}t] [%-m:%l] [pid %P:tid %T] %7F: %E: [client %a] %M% ,\ referer\ %{Referer}i %v"
And add the env to not log static file :
setenvIf Request_URI ".(jpg|jpeg|png|css|gif|ico|js|webp)$" dontlog
Once you have done all of this, creating new template, making change to configuration files, then you have to apply the new template to all your website. Some scripts with the cli will help for that.
Make sure to test on few site before applying to everything.
Note : this will break your awstats if you use some of them.
One master process has a soft limit of 1024 I just saw my log in the first post, maybe that i the root issue?
I have not been able to alter that in any way, despite plowing through posts like linux - How to set nginx max open files? - Stack Overflow
Apache or NGinx ?
nginx, see above Too many open files despite config adjustments
latest message from /var/log/nginx/error.log: 2023/09/27 22:01:29 [emerg] 183427#183427: open() "/var/log/nginx/domains/webmail.CENSORED.com.log" failed (24: Too many open files)
hm that script to regenerate templates would be handy
and awstats is not required, but would be handy to have working
did you check the worker_rlimit_nofile in nginx.conf ?
Did you set a LimitNOFILE in systemd for nginx ?
How did you setup the limits in security/limits.conf ?
Did you try to increase the limit far more than 65k ?
Did you restart your server after all those change ?
After reading the whole thread it seem that you have done those change.
But you should check the limit for apache2 too, because nginx and apache run with the same users.
For apache check the /etc/apache2/envvars file and this line :
APACHE_ULIMIT_MAX_FILES='ulimit -n 65536'
And about awstats, you need to configure it yourself with custom logtype if you want to use a unique log file. Or you will need to keep 1 log file / domain.
[EDIT]
What give you thoses command :
sysctl fs.file-max
sysctl fs.aio-max-nr
[/EDIT]
Yep, I have made countless raises and reboots. This issue already sucked up hours that might have been better invested splitting up our instance or something…
$ sysctl fs.file-max fs.aio-max-nr
fs.file-max = 70000
fs.aio-max-nr = 65536
Now trying your configuration hacks with rebuild via Force Reload From Template,
though these configurations should probably go into respective subfolders so they can easily be toggled.
Why is this 1024 limit still there after raising everything?
janek@main:~ :) $ sudo ps ux | grep nginx
root         759  0.0  0.0  21084  1384 ?        Ss   12:20   0:00 nginx: master process /usr/local/hestia/nginx/sbin/hestia-nginx
root        1684  0.0  0.7 188236 131536 ?       Ss   12:20   0:00 nginx: master process /usr/sbin/nginx -c /etc/nginx/nginx.conf
janek@main:~ :) $ sudo cat /proc/759/limits
Limit                     Soft Limit           Hard Limit           Units
Max cpu time              unlimited            unlimited            seconds
Max file size             unlimited            unlimited            bytes
Max data size             unlimited            unlimited            bytes
Max stack size            8388608              unlimited            bytes
Max core file size        0                    unlimited            bytes
Max resident set          unlimited            unlimited            bytes
Max processes             71810                71810                processes
Max open files            1024                 524288               files
Max locked memory         65536                65536                bytes
Max address space         unlimited            unlimited            bytes
Max file locks            unlimited            unlimited            locks
Max pending signals       71810                71810                signals
Max msgqueue size         819200               819200               bytes
Max nice priority         0                    0
Max realtime priority     0                    0
Max realtime timeout      unlimited            unlimited            us
Now this is odd:
janek@main:conf :) $ sudo ps ux | grep nginx
root       43483  0.0  0.0  21148  1372 ?        Ss   12:32   0:00 nginx: master process /usr/local/hestia/nginx/sbin/hestia-nginx
root       49767  0.0  0.3 126792 66048 ?        Ss   12:43   0:00 nginx: master process /usr/sbin/nginx -c /etc/nginx/nginx.conf
janek@main:conf :) $ sudo lsof -p 43483 | wc -l
22
janek@main:conf :) $ sudo lsof -p 49767 | wc -l
1252
janek@main:conf  1 $ sudo lsof | awk '{print $1}' | sort | uniq -c | sort -h | tail -5
   2084 php-fpm7.
   7328 named
  15039 nginx
  30265 mariadbd
  66235 apache2
which nginx process is opening all those files?
Something we cant really say without access to the server…
ah I missed the workers, I think I might not be too far from the solution:
$ sudo ps aux | grep nginx
admin      43484  0.0  0.0  22312  8088 ?        S    12:32   0:00 nginx: worker process
www-data   49768  2.6  0.3 127032 72588 ?        S    12:43   0:09 nginx: worker process
www-data   49769  0.0  0.3 127032 71864 ?        S    12:43   0:00 nginx: worker process
www-data   49770  0.0  0.3 127032 71076 ?        S    12:43   0:00 nginx: worker process
www-data   49772  0.0  0.3 127032 68008 ?        S    12:43   0:00 nginx: worker process
www-data   49773  0.0  0.3 127032 68008 ?        S    12:43   0:00 nginx: worker process
www-data   49774  0.0  0.3 127032 68008 ?        S    12:43   0:00 nginx: worker process
www-data   49775  0.0  0.3 127032 68008 ?        S    12:43   0:00 nginx: worker process
www-data   49776  0.0  0.3 127032 68008 ?        S    12:43   0:00 nginx: worker process
www-data   49777  0.0  0.3 127032 68008 ?        S    12:43   0:00 nginx: worker process
www-data   49778  0.0  0.3 127032 68008 ?        S    12:43   0:00 nginx: worker process
www-data   49779  0.0  0.3 127032 67788 ?        S    12:43   0:00 nginx: cache manager process
please, can anyone help here?
sysctl limits definitely seem to be irrelevant:
$ sudo sysctl fs.file-max fs.file-nr fs.aio-max-nr fs.aio-nr
fs.file-max = 9223372036854775807
fs.file-nr = 7168	0	9223372036854775807
fs.aio-max-nr = 1048576
fs.aio-nr = 352
https://www.kernel.org/doc/html/latest/admin-guide/sysctl/fs.html#file-max-file-nr
this I get when the restart fails:
nginx: [emerg] open() "/var/log/nginx/domains/webmail.DOMAIN.error.log" failed (24: Too many open files)
nginx: configuration file /etc/nginx/nginx.conf test failed
but initiating v-restart-proxy from the CLI works just fine:
so how can I reproduce this?
