This is all that appears in the debug logs with DEBUG_MODE:
[ 2023-11-16 14:25:33 | nginx ]
[ 2023-11-16 14:25:33 | nginx | PROXY ]
It can also be restricted from host system if you run via virtual machineā¦
It is hard to debug what happens and what goed wrong for sure without any server accessā¦
I have advanced: The issue only occurs when operating from the webpanel, probably because there service nginx configtest forks from the hestia-php process.
Now I just need to find out to raise the limit of that process.
I had to raise the limit in /usr/local/hestia/php/etc/php-fpm.conf
[global]
rlimit_files=65535
See PHP: Configuration - Manual
Then systemctl restart hestia and everything is working.
The default as detected with prlimit --pid= was 1024, I would suggest adjusting that up by default. This took me many hours of work to debug and fix for good.
Can I somehow make this change permanent? Hestia will probably overwrite it on upgradeā¦
Use an hook:
