I needed a simple app to help me generates templates for PHP-FPM and manage wildcard certificates, but I use Cloudflare for manage dns, so I built this simple CLI app.
Features:
Manage a wildcard certificates with an external DNS provider (supports Cloudflare and Gandi for now)
PHP-FPM template generation
Generates reverse proxy templates for http, https and unix sockets
Needless to say, the tool is far from mature and still pretty much beta, any suggestion, bugreport, feature and PRs are highly appreciated.
I would like to introduce those features upstream someday, this was a good chance to start digging inside the HestiaCP codebase.
Is a CLI app made in php, where you can generate fpm templates, specifying workers, timeout etc for now, that are automatically placed inside HestaCP directories, so you can select it on the panel for the website you want.
Same thing for the reverse proxy templates.
The wildcard certs manager: so hestiacp does not let you generate LE certificates for wildcards domains that are not managed by hestia dns server himself, so this is an external way overcome this limitation: it will handle the request and renewal, installation, and so on.
$ php ./hcpc; echo " ";for i in $(php ./hcpc | sed -r '/^$/d' | tail -n +3 | awk '{print $1}');do echo -e "## Command $i\n\n";php ./hcpc help $i; echo "";done
HestiaCP Companion 2.0.2
USAGE: <command> [options] [arguments]
php-template Makes a custom PHP-FPM template
reverse-proxy Install templates to create reverse proxy sites
self-update Allows to self-update a build application
certificate:add-wildcard Save a new wildcard domain to the system
certificate:remove Remove a certificate from the hcpc subsystem
certificate:renew Renew certificates that are about to expire
hestia:add-cron Add a cron to HestiaCP to invoke the hpcp scheduler
## Command php-template
Description:
Usage:
php-template [options] [--] [<name>]
Arguments:
name [default: "custom"]
Options:
--phpVersion[=PHPVERSION]
--maxChildren[=MAXCHILDREN] [default: "10"]
--processIdleTimeout[=PROCESSIDLETIMEOUT] [default: "5"]
--maxRequests[=MAXREQUESTS] [default: "10000"]
-h, --help Display help for the given command. When no command is given display help for the list command
-q, --quiet Do not output any message
-V, --version Display this application version
--ansi|--no-ansi Force (or disable --no-ansi) ANSI output
-n, --no-interaction Do not ask any interactive question
--env[=ENV] The environment the command should run under
-v|vv|vvv, --verbose Increase the verbosity of messages: 1 for normal output, 2 for more verbose output and 3 for debug
## Command reverse-proxy
Description:
Usage:
reverse-proxy
Options:
## Command self-update
Description:
Usage:
self-update
Options:
## Command certificate:add-wildcard
Description:
Usage:
Options:
## Command certificate:remove
Description:
Usage:
certificate:remove
Options:
## Command certificate:renew
Description:
Usage:
certificate:renew
Options:
## Command hestia:add-cron
Description:
Usage:
hestia:add-cron
Options:
