Transfer Web Domains
I have web domains, emails et all that belongs to Hestia Admin, is there a way to them to another user?
CLI command from console:
v-change-domain-owner
Usage: v-change-domain-owner DOMAIN USER
The above worked like a charm
v-change-domain-owner {DOMAIN} {NEWUSERNAME}
Hi Chembian and all
perhaps anyone can help me out, i got this mesage when i try to change domain owner.
i am using hestia 1.3 version
and the domain is not change
i mean that there are no result, domain still own by old user
thanks
Did you execute the command as root?
yups, i execute it as root user
the $ prompt suggests that you haven’t been root # though…
anyway seems like a issue with the PATH variable, how did you become root? which OS?
I am using ohmyzsh with “ys” theme
and
this is how become root and i am using ubuntu 20.04
this is the path variable
try adding:
export HESTIA=/usr/local/hestia
@falzo
Work seamlessly buddy
Thanks lot bro
I would like to change owner of domain to another, but I suspicous to will may broke the system. Does the comand still work?
This is a 3 year old topic.
v-change-domain-owner should do the trick…
