When I restore the backup, it restores no database and from what I can see it only restored the domains and users. The file looks to have the database in it, package has space for 2 databases. so I am not sure how to fix it.
You can use separate recovery, unzip your overall backup, extract the database file you need to import, and use the import command to import it into your newly created database. Then copy the website file to your current website directory!
