Hi guys, try installing LaraClassifier script on Laravel. Install ask open_basedir off, no instal before do it open_basedir . I have from forum instructions how open_basedir off, all do it and site no wotk, error 50, and install go to 500 error.
see what i do:
Debian 13
/usr/local/hestia/data/templates/web/php-fpm/ -
change to
sed -i 's/php_admin_value\[open_basedir\]/;php_admin_value\[open_basedir\]/g' /usr/local/hestia/data/templates/web/php-fpm/PHP-8_4tpl -
v-change-web-domain-backend-tpl salerainbow salerainbow.com PHP-8_4
after wedsite no work, no open anymore info.php no open too error 500
[Sun Oct 11 15:06:03.437781 2026] [proxy:error] [pid 1206:tid 1249] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /run/php/php8.4-fpm-salerainbow.com.sock (localhost:8000) failed
[Sun Oct 11 15:06:03.437815 2026] [proxy_fcgi:error] [pid 1206:tid 1249] [client 74.7.243.232:0] AH01079: failed to make connection to backend: localhost, referer: https://salerainbow.com/?o=6509262491
[Sun Oct 11 15:06:04.301870 2026] [proxy:error] [pid 1209:tid 1273] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /run/php/php8.4-fpm-salerainbow.com.sock (localhost:8000) failed
[Sun Oct 11 15:06:04.301909 2026] [proxy_fcgi:error] [pid 1209:tid 1273] [client 16.216.88.70:0] AH01079: failed to make connection to backend: localhost
[Sun Oct 11 15:06:12.729048 2026] [core:error] [pid 1209:tid 1275] [client 57.141.18.19:0] AH00124: Request exceeded the limit of 10 internal redirects due to probable configuration error. Use 'LimitInternalRecursion' to increase the limit if necessary. Use 'LogLevel debug' to get a backtrace.
[Sun Oct 11 15:06:12.729089 2026] [core:error] [pid 1209:tid 1275] [client 57.141.18.19:0] AH00124: Request exceeded the limit of 10 internal redirects due to probable configuration error. Use 'LimitInternalRecursion' to increase the limit if necessary. Use 'LogLevel debug' to get a backtrace.
[Sun Oct 11 15:06:16.396366 2026] [core:error] [pid 1209:tid 1277] [client 16.216.88.216:0] AH00124: Request exceeded the limit of 10 internal redirects due to probable configuration error. Use 'LimitInternalRecursion' to increase the limit if necessary. Use 'LogLevel debug' to get a backtrace.
[Sun Oct 11 15:06:16.396391 2026] [core:error] [pid 1209:tid 1277] [client 16.216.88.216:0] AH00124: Request exceeded the limit of 10 internal redirects due to probable configuration error. Use 'LimitInternalRecursion' to increase the limit if necessary. Use 'LogLevel debug' to get a backtrace.
[Sun Oct 11 15:06:23.461008 2026] [autoindex:error] [pid 1209:tid 1246] [client 74.7.243.232:0] AH01276: Cannot serve directory /home/salerainbow/web/salerainbow.com/public_html/: No matching DirectoryIndex (index.html,index.cgi,index.pl,index.php,index.xhtml,index.htm) found, and server-generated directory index forbidden by Options directive, referer: https://salerainbow.com/?u=27892111221
[Sun Oct 11 15:06:24.578824 2026] [proxy:error] [pid 1206:tid 1212] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /run/php/php8.4-fpm-salerainbow.com.sock (localhost:8000) failed
[Sun Oct 11 15:06:24.578863 2026] [proxy_fcgi:error] [pid 1206:tid 1212] [client 216.25.254.172:0] AH01079: failed to make connection to backend: localhost
[Sun Oct 11 15:06:43.482652 2026] [autoindex:error] [pid 1209:tid 1263] [client 74.7.243.232:0] AH01276: Cannot serve directory /home/salerainbow/web/salerainbow.com/public_html/: No matching DirectoryIndex (index.html,index.cgi,index.pl,index.php,index.xhtml,index.htm) found, and server-generated directory index forbidden by Options directive, referer: https://salerainbow.com/?g=31674130512
[Sun Oct 11 15:07:03.473908 2026] [autoindex:error] [pid 1206:tid 1216] [client 74.7.243.232:0] AH01276: Cannot serve directory /home/salerainbow/web/salerainbow.com/public_html/: No matching DirectoryIndex (index.html,index.cgi,index.pl,index.php,index.xhtml,index.htm) found, and server-generated directory index forbidden by Options directive, referer: https://salerainbow.com/?a=70564169373
