I installed Hestia on my dev server and so far looks good! Thank you!
I have created a website/domain name owned by an unprivileged user (as recommended by the docs at /admin_docs/users.html#why-should-i-never-host-a-website-under-admin-account - sorry, it says I can’t put more than 2 links). Now lets say I want two devs to work on that website at the same time.
The easiest would be to share the SSH and FTP credentials of that unprivileged account I created, but it sounds like a bad idea because:
they’ll share the same git config; their commits will have the same name and email
they’ll share the same bash history
Is there a way with Hestia to create multiple unprivileged users and make each have SSH access to the same website owned by me, for example? Or should I retract to manually creating and jailing some SSH users?
Don’t share code base on a server but keep each code base separate and only after deloy after merge and so on with continues integration. Or use a local developing machine…
Hestia is not designed with 2 devs on server as many other control panels. We support multiple ftp accounts and consider adding support for multiple sftp accounts but the current implentation for ssh currently so bad that it needs quite a lot rewrite including setting up rssh and so on…
Create 2 different user accounts that have access each and their own website so they can break stuff thing
