I am sure that part of this problem is the fact that I am installing Hestia on a VirtualBox Debian VM rather than a real VPS. After many days and many failed attempts, I have given up on trying to custom install Hestia on Debian 10. Instead, I went with the standard install: sudo bash hst-install.sh
Sadly, at the end there were two errors preventing the install.
The first problem is that a folder called networkd-dispatcher is definitely missing from the usr/ lib folder. It appears that Debian may have moved this folder to a different location. I thought perhaps I could just get around this problem by not installing Fail2Ban but that did not work.
The second problem is that an Apache 2 module/ file called remoteip.conf not properly enabled. I opened this file and could not find anything wrong with it. I do not understand why it was not enabled.
Any ideas on how to solve either of these problems would be greatly appreciated.
Below is the install information I copied from the terminal starting at the point the errors started occurring:
Thanks for your help and input!
Configuring fail2ban access monitor…
/usr/local/hestia/bin/v-update-firewall: line 187: /usr/lib/networkd-dispatcher/routable.d/50-ifup-hooks: No such file or directory
/usr/local/hestia/bin/v-update-firewall: line 188: /usr/lib/networkd-dispatcher/routable.d/50-ifup-hooks: No such file or directory
/usr/local/hestia/bin/v-update-firewall: line 189: /usr/lib/networkd-dispatcher/routable.d/50-ifup-hooks: No such file or directory
/usr/local/hestia/bin/v-update-firewall: line 190: /usr/lib/networkd-dispatcher/routable.d/50-ifup-hooks: No such file or directory
/usr/local/hestia/bin/v-update-firewall: line 191: /usr/lib/networkd-dispatcher/routable.d/50-ifup-hooks: No such file or directory
/usr/local/hestia/bin/v-update-firewall: line 192: /usr/lib/networkd-dispatcher/routable.d/50-ifup-hooks: No such file or directory
/usr/local/hestia/bin/v-update-firewall: line 193: /usr/lib/networkd-dispatcher/routable.d/50-ifup-hooks: No such file or directory
/usr/local/hestia/bin/v-update-firewall: line 194: /usr/lib/networkd-dispatcher/routable.d/50-ifup-hooks: No such file or directory
/usr/local/hestia/bin/v-update-firewall: line 195: /usr/lib/networkd-dispatcher/routable.d/50-ifup-hooks: No such file or directory
chmod: cannot access ‘/usr/lib/networkd-dispatcher/routable.d/50-ifup-hooks’: No such file or directory
ERROR: Config file remoteip.conf not properly enabled: /etc/apache2/mods-enabled/remoteip.conf is a real file, not touching it
Here is how I opened this file and what was in it:
cd /etc/apache2/mods-enabled/
sudo nano remoteip.conf
RemoteIPHeader X-Real-IP
RemoteIPInternalProxy 127.0.0.1
RemoteIPInternalProxy 192.168.56.101
RemoteIPInternalProxy 76.121.122.172
RemoteIPInternalProxy 10.0.2.15
Searched apache2 mods-enabled remoteip.config not properly enabled Found nothing that helped. This may be related to the fact that my virtual server is a virtual machine inside of VirtualBox.
