Could it be possible that to enter webmail or to configure an account on a device or PC, a 2FA validation could be created? similar to what gmail or microsoft already do? I would gain a lot in security.
No, exim4 does not support 2FA. On webmail, you can setup webmails plugins. For example roundcube:
Not tested.
Thankâs
I always have the same problem with roundcube plugins⌠in what exact path should I put it? If I put it in /etc/rouncube/pluguins and then add the following in /etc/roundcube/config.inc.php;
$config[âpluginsâ] = array(âtwofactor_gauthenticatorâ);
It doesnât work, roundcube doesnât show the option to activate that pluginâŚ
Hello @servtelecom,
Steps to install twofactor_gauthenticator
rc plugin in Hestia CP:
cd /var/lib/roundcube/plugins/
git clone https://github.com/alexandregz/twofactor_gauthenticator.git
cd twofactor_gauthenticator/
cp config.inc.php.dist config.inc.php
mkdir /etc/roundcube/plugins/twofactor_gauthenticator/
cd /etc/roundcube/plugins/twofactor_gauthenticator/
ln -s /var/lib/roundcube/plugins/twofactor_gauthenticator/config.inc.php config.inc.php
chown -R root:www-data /etc/roundcube/plugins/twofactor_gauthenticator/
chown -R root:www-data /var/lib/roundcube/plugins/twofactor_gauthenticator/
Now edit /etc/roundcube/config.inc.php
file to add twofactor_gauthenticator
to config_plugins
directive.
Example:
$config["plugins"] = ["password", "newmail_notifier", "zipdownload", "archive", "managesieve", "contextmenu", "markasjunk", "twofactor_gauthenticator"];
Now edit file /etc/roundcube/plugins/twofactor_gauthenticator/config.inc.php
to configure the preferences for the plugin (donât forget to edit users_allowed_2FA
in this config file to enable the plugin for your user or domain).
Cheers,
sahsanu
