I’ve tried to instal the new alpha 1.4.0 on my test server with Ubuntu 20.04. When I installed the package, the files were installed, but the installation script didn’t run.
root@:~# dpkg -i hestia_1.4.0~alpha_amd64.deb
Selecting previously unselected package hestia.
(Reading database … 108974 files and directories currently installed.)
Preparing to unpack hestia_1.4.0~alpha_amd64.deb …
Unpacking hestia (1.4.0~alpha) …
Setting up hestia (1.4.0~alpha) …
root@:~#
When I had a look in the folder /usr/local/hestia/install, I recognized the install script was missing the executable bit.
root@:/usr/local/hestia/install# ls -la
total 160
drwxrwxr-x 5 root root 4096 Mar 4 20:21 .
drwxr-xr-x 6 root root 4096 Mar 4 20:21 …
drwxrwxr-x 28 root root 4096 Mar 4 20:21 deb
-rwxrwxr-x 1 root root 67592 Feb 28 12:18 hst-install-debian.sh
-rw-rw-r-- 1 root root 3070 Feb 28 12:18 hst-install.sh
-rwxrwxr-x 1 root root 68870 Feb 28 12:18 hst-install-ubuntu.sh
drwxrwxr-x 26 root root 4096 Mar 4 20:21 rhel
drwxrwxr-x 4 root root 4096 Mar 4 20:21 upgrade
After I’ve set the executable bit, I was able to run the installation script manually.
Sorry, I forgot the procedure for a clean install of a beta version. Now it worked. Thank you.
I’ve restored a backup from a hestiacp 1.3.3 server and got the following messeges during restore:
– MAIL –
2021-03-04 21:44:02 xxxxxxxxxxxxxxxxxx
Error: WEBMAIL_ALIAS is not defined in hestia.conf.
Usage: grep [OPTION]… PATTERNS [FILE]…
Try ‘grep --help’ for more information.
Error: type is invalid
When I edit a mail account, the “Webmail Alias” is not shown correctly. On the old server it was http://webmail.domain. Now it is http://.domain .
During the update of hestia I’ve got the following errors when processing the user, where the backup has shown the errors before:
[ * ] Rebuilding user accounts and domains:
- admin:
---- Web domains…
---- DNS zones…
---- Mail domains…
---- User configuration…
- xxxxxxxx:
---- Web domains…
---- DNS zones…
---- Mail domains…
[ * ] Applying user interface updates…
When I delete the user and reimport the backup, the WEBMAIL_ALIAS error isn’t shown any more, but the grep errors are still shown:
– MAIL –
2021-03-06 20:39:47 prangerschuetzen-ebenau.at
Thank you. After running v-add-sys-roundcube and v-update-web-templates, v-update-mail-templates and v-update-dns-templates the error has gone. I even can import the backup without any problems.
Had the same trouble as OP and thought it was funny the app first prompts to uninstall itself before proceeding with the install lol. In any case, i followed the install instructions for “–with-debs” installation and noticed that the was also still an error with the roundcube installation during the hestia installation. Something about unknown path. The installation proceeded but I went to run the “v-add-” for roundcube and the 3 templates that are marked as solution but I can’t find them anywhere?!?
As noted in my previous post, I had to run the three scripts v-update-web-templates, v-update-mail-templates and v-update-dns-templates, not the three scripts mentioned in eris’ post, which started with “v-add-”.
