The install process should also allow choosing which versions of PHP to install using MultiPHP.
Ubuntu 20 Focal Fossa supports only PHP > 7.2, so no need to install older versions.
Just install it without multipho, then add the version afterwards over v-add-web-php or server settings under the web tab.
We use php packages build by Sury and the also support 5.6 7.0 and 7.1
Great, I already installed it. Is there a similar way to uninstall some? Or can I remove those packages directly via apt?
v-delete-web-php x.x
