Ubuntu 24.04.1 LTS [no valid OpenPGP data found]
Hello. I trying to install beta version of hestia on ubuntu 24.04.1 LTS from manual and when I run the command:
curl -s "https://beta-apt.hestiacp.com/pubkey.gpg" | gpg --dearmor | tee /usr/share/keyrings/hestia-beta-keyring.gpg > /dev/null 2>&1
I get this error: no valid OpenPGP data found. Wget same don’t work. If I run wget https://apt.hestiacp.com/ then the command works correctly. How I fix this issue?
It works fine from my side:
❯ curl -s "https://beta-apt.hestiacp.com/pubkey.gpg"
-----BEGIN PGP PUBLIC KEY BLOCK-----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=yg6F
-----END PGP PUBLIC KEY BLOCK-----
Show the output of this command;
curl -v "https://beta-apt.hestiacp.com/pubkey.gpg"
* Host beta-apt.hestiacp.com:443 was resolved.
* IPv6: (none)
* IPv4: 116.203.224.113
*   Trying 116.203.224.113:443...
* connect to 116.203.224.113 port 443 from 192.168.1.23 port 54292 failed: Connection timed out
* Failed to connect to beta-apt.hestiacp.com port 443 after 133897 ms: Couldn't connect to server
* Closing connection
curl: (28) Failed to connect to beta-apt.hestiacp.com port 443 after 133897 ms: Couldn't connect to server
And
* Host apt.hestiacp.com:443 was resolved.
* IPv6: 2606:4700:20::681a:bed, 2606:4700:20::681a:aed, 2606:4700:20::ac43:48b7
* IPv4: 188.114.98.229, 188.114.99.229
*   Trying 188.114.98.229:443...
* Connected to apt.hestiacp.com (188.114.98.229) port 443
* ALPN: curl offers h2,http/1.1
* TLSv1.3 (OUT), TLS handshake, Client hello (1):
*  CAfile: /etc/ssl/certs/ca-certificates.crt
*  CApath: /etc/ssl/certs
* TLSv1.3 (IN), TLS handshake, Server hello (2):
* TLSv1.3 (IN), TLS handshake, Encrypted Extensions (8):
* TLSv1.3 (IN), TLS handshake, Certificate (11):
* TLSv1.3 (IN), TLS handshake, CERT verify (15):
* TLSv1.3 (IN), TLS handshake, Finished (20):
* TLSv1.3 (OUT), TLS change cipher, Change cipher spec (1):
* TLSv1.3 (OUT), TLS handshake, Finished (20):
* SSL connection using TLSv1.3 / TLS_AES_256_GCM_SHA384 / X25519 / id-ecPublicKey
* ALPN: server accepted h2
* Server certificate:
*  subject: CN=hestiacp.com
*  start date: Dec  3 12:00:41 2024 GMT
*  expire date: Mar  3 12:00:40 2025 GMT
*  subjectAltName: host "apt.hestiacp.com" matched cert's "*.hestiacp.com"
*  issuer: C=US; O=Google Trust Services; CN=WE1
*  SSL certificate verify ok.
*   Certificate level 0: Public key type EC/prime256v1 (256/128 Bits/secBits), signed using ecdsa-with-SHA256
*   Certificate level 1: Public key type EC/prime256v1 (256/128 Bits/secBits), signed using ecdsa-with-SHA384
*   Certificate level 2: Public key type EC/secp384r1 (384/192 Bits/secBits), signed using ecdsa-with-SHA384
* using HTTP/2
* [HTTP/2] [1] OPENED stream for https://apt.hestiacp.com/pubkey.gpg
* [HTTP/2] [1] [:method: GET]
* [HTTP/2] [1] [:scheme: https]
* [HTTP/2] [1] [:authority: apt.hestiacp.com]
* [HTTP/2] [1] [:path: /pubkey.gpg]
* [HTTP/2] [1] [user-agent: curl/8.5.0]
* [HTTP/2] [1] [accept: */*]
> GET /pubkey.gpg HTTP/2
> Host: apt.hestiacp.com
> User-Agent: curl/8.5.0
> Accept: */*
* TLSv1.3 (IN), TLS handshake, Newsession Ticket (4):
* old SSL session ID is stale, removing
< HTTP/2 200
< date: Thu, 09 Jan 2025 18:18:54 GMT
< content-type: application/octet-stream
< content-length: 3159
< last-modified: Mon, 26 Aug 2024 08:43:56 GMT
< etag: "66cc404c-c57"
< strict-transport-security: max-age=15768000
< accept-ranges: bytes
< cf-cache-status: DYNAMIC
< report-to: {"endpoints":[{"url":"https:\/\/a.nel.cloudflare.com\/report\/v4?s=j7w18BkLNAzdgfOuQ2P15JfyFrdwpbGjknvQEwFAAKfkbe2WOqBHqqk9WwatOIJbud7lg0j2PH6pPOTW%2FQ1J4e3YB9VP8ST3IExpY9z35lj%2Br4gi%2FOcMX%2FQUxCM2Lgks9ZQ%3D"}],"group":"cf-nel","max_age":604800}
< nel: {"success_fraction":0,"report_to":"cf-nel","max_age":604800}
< server: cloudflare
< cf-ray: 8ff66ebd1cb66fc3-CDG
< server-timing: cfL4;desc="?proto=TCP&rtt=88829&min_rtt=88417&rtt_var=33450&sent=6&recv=7&lost=0&retrans=0&sent_bytes=3409&recv_bytes=755&delivery_rate=32753&cwnd=196&unsent_bytes=0&cid=710d051a830088f1&ts=227&x=0"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=6H1w
* Connection #0 to host apt.hestiacp.com left intact
Maybe you are being blocked.
@eris could you please check where there are some rule blocking some ips?
@Abrikos, please share your public ip with @eris
There is no firewall in front of the beta server…
Also @Abrikos was able to connect to it via his private computer… (On the same network)
Hello, please share the link to the alpha version installation guide. Thank you
I solved my problem. I marked the packet of this server on the router and changed the entry point to the Internet for this server using my VPN server in Amsterdam. Everything downloaded and installed without problems. I don’t know how my computer running Windows 10 gets access to the necessary resources through the browser, but the server can’t do this! I suspect that there is a blocking at some point, but I’m too lazy to capture and analyze the traffic. From Crimea with love!
