Unable to Access Control Panel - Error 500
Dear Support Team,
I have been using the Hostia Control Panel for more than a year without any issues. However, I am now encountering an Internal Server Error (Error Code: 500) when trying to access the Control Panel at the following link:
https://host.decastro.group:8083/login/
All websites hosted under the server are running properly, but I am unable to access the Control Panel. Additionally, it seems that some services have stopped or been turned off unexpectedly.
Could you please help me resolve this issue as soon as possible? I am not sure what caused the error. Your prompt assistance will be greatly appreciated.
Thank you.
Best regards,
Tamim Iqbal
Hi Tamim,
What do you see in the logs /var/log/hestia/nginx-error.log?
2024/10/16 13:57:07 [error] 10023#0: *30 FastCGI sent in stderr: "PHP message: PHP Warning:  session_start(): open(/usr/local/hestia/data/sessions/sess_auovticqjfqc80qu0001ntv8lk, O_RDWR) failed: Permission denied (13) in /usr/local/hestia/web/inc/main.php on line 2; PHP message: PHP Warning:  session_start(): Failed to read session data: files (path: /usr/local/hestia/data/sessions) in /usr/local/hestia/web/inc/main.php on line 2; PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning:  foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning:  Undefined array key "RELEASE_BRANCH" in /usr/local/hestia/web/inc/main.php on line 105; PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning:  foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Fatal error:  Uncaught TypeError: in_array(): Argument #2 ($haystack) must be of type array, null given in /usr/local/hestia/web/login/index.php:436
Stack trace:
#0 /usr/local/hestia/web/login/index.php(436): in_array()
#1 {main}
  thrown in /usr/local/hestia/web/login/index.php on line 436" while reading response header from upstream, client: 103.131.80.30, server: _, request: "GET /login/ HTTP/2.0", upstream: "fastcgi://unix:/run/hestia-php.sock:", host: "185.28.22.62:8083"
2024/10/16 14:00:50 [error] 10023#0: *34 FastCGI sent in stderr: "PHP message: PHP Warning:  session_start(): open(/usr/local/hestia/data/sessions/sess_auovticqjfqc80qu0001ntv8lk, O_RDWR) failed: Permission denied (13) in /usr/local/hestia/web/inc/main.php on line 2; PHP message: PHP Warning:  session_start(): Failed to read session data: files (path: /usr/local/hestia/data/sessions) in /usr/local/hestia/web/inc/main.php on line 2; PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning:  foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning:  Undefined array key "RELEASE_BRANCH" in /usr/local/hestia/web/inc/main.php on line 105; PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning:  foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Fatal error:  Uncaught TypeError: in_array(): Argument #2 ($haystack) must be of type array, null given in /usr/local/hestia/web/login/index.php:436
Stack trace:
#1 {main}
2024/10/16 14:14:54 [error] 855#0: *9 FastCGI sent in stderr: "PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning:  foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning:  Undefined array key "RELEASE_BRANCH" in /usr/local/hestia/web/inc/main.php on line 105; PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning:  foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Fatal error:  Uncaught TypeError: in_array(): Argument #2 ($haystack) must be of type array, null given in /usr/local/hestia/web/login/index.php:436
Stack trace:
#1 {main}
2024/10/16 14:15:28 [error] 855#0: *10 FastCGI sent in stderr: "PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning:  foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning:  Undefined array key "RELEASE_BRANCH" in /usr/local/hestia/web/inc/main.php on line 105; PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning:  foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Fatal error:  Uncaught TypeError: in_array(): Argument #2 ($haystack) must be of type array, null given in /usr/local/hestia/web/login/index.php:436
Stack trace:
#1 {main}
2024/10/16 14:15:44 [error] 855#0: *10 FastCGI sent in stderr: "PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning:  foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning:  Undefined array key "RELEASE_BRANCH" in /usr/local/hestia/web/inc/main.php on line 105; PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning:  foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Fatal error:  Uncaught TypeError: in_array(): Argument #2 ($haystack) must be of type array, null given in /usr/local/hestia/web/login/index.php:436
Stack trace:
#1 {main}
2024/10/16 14:17:51 [error] 826#0: *5 FastCGI sent in stderr: "PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning:  foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning:  Undefined array key "RELEASE_BRANCH" in /usr/local/hestia/web/inc/main.php on line 105; PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning:  foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Fatal error:  Uncaught TypeError: in_array(): Argument #2 ($haystack) must be of type array, null given in /usr/local/hestia/web/login/index.php:436
Stack trace:
#1 {main}
2024/10/16 14:18:58 [error] 826#0: *8 FastCGI sent in stderr: "PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning:  foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning:  Undefined array key "RELEASE_BRANCH" in /usr/local/hestia/web/inc/main.php on line 105; PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning:  foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Fatal error:  Uncaught TypeError: in_array(): Argument #2 ($haystack) must be of type array, null given in /usr/local/hestia/web/login/index.php:436
Stack trace:
#1 {main}
  thrown in /usr/local/hestia/web/login/index.php on line 436" while reading response header from upstream, client: 103.131.80.30, server: _, request: "GET /login/ HTTP/2.0", upstream: "fastcgi://unix:/run/hestia-php.sock:", host: "host.decastro.group:8083"
2024/10/16 14:40:27 [error] 826#0: *16 FastCGI sent in stderr: "PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning:  foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning:  Undefined array key "RELEASE_BRANCH" in /usr/local/hestia/web/inc/main.php on line 105; PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning:  foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Fatal error:  Uncaught TypeError: in_array(): Argument #2 ($haystack) must be of type array, null given in /usr/local/hestia/web/login/index.php:436
Stack trace:
#1 {main}
2024/10/16 14:54:30 [error] 802#0: *1 FastCGI sent in stderr: "PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning:  foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning:  Undefined array key "RELEASE_BRANCH" in /usr/local/hestia/web/inc/main.php on line 105; PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning:  foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Fatal error:  Uncaught TypeError: in_array(): Argument #2 ($haystack) must be of type array, null given in /usr/local/hestia/web/login/index.php:436
Stack trace:
#1 {main}
2024/10/16 15:39:26 [error] 802#0: *6 FastCGI sent in stderr: "PHP message: PHP Warning:  session_start(): open(/usr/local/hestia/data/sessions/sess_lrvdv9mpoir96pq2huomaqiklh, O_RDWR) failed: Permission denied (13) in /usr/local/hestia/web/index.php on line 2; PHP message: PHP Warning:  session_start(): Failed to read session data: files (path: /usr/local/hestia/data/sessions) in /usr/local/hestia/web/index.php on line 2" while reading response header from upstream, client: 103.131.80.30, server: _, request: "GET / HTTP/2.0", upstream: "fastcgi://unix:/run/hestia-php.sock:", host: "host.decastro.group:8083"
2024/10/16 15:39:26 [error] 802#0: *6 FastCGI sent in stderr: "PHP message: PHP Warning:  session_start(): open(/usr/local/hestia/data/sessions/sess_lrvdv9mpoir96pq2huomaqiklh, O_RDWR) failed: Permission denied (13) in /usr/local/hestia/web/inc/main.php on line 2; PHP message: PHP Warning:  session_start(): Failed to read session data: files (path: /usr/local/hestia/data/sessions) in /usr/local/hestia/web/inc/main.php on line 2; PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning:  foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning:  Undefined array key "RELEASE_BRANCH" in /usr/local/hestia/web/inc/main.php on line 105; PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning:  foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Fatal error:  Uncaught TypeError: in_array(): Argument #2 ($haystack) must be of type array, null given in /usr/local/hestia/web/login/index.php:436
Stack trace:
#1 {main}
2024/10/16 15:48:39 [error] 802#0: *10 FastCGI sent in stderr: "PHP message: PHP Warning:  session_start(): open(/usr/local/hestia/data/sessions/sess_g5ba6kvu3suimr7jigjea1s40l, O_RDWR) failed: Permission denied (13) in /usr/local/hestia/web/inc/main.php on line 2; PHP message: PHP Warning:  session_start(): Failed to read session data: files (path: /usr/local/hestia/data/sessions) in /usr/local/hestia/web/inc/main.php on line 2; PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning:  foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning:  Undefined array key "RELEASE_BRANCH" in /usr/local/hestia/web/inc/main.php on line 105; PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning:  foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Fatal error:  Uncaught TypeError: in_array(): Argument #2 ($haystack) must be of type array, null given in /usr/local/hestia/web/login/index.php:436
Stack trace:
#1 {main}
  thrown in /usr/local/hestia/web/login/index.php on line 436" while reading response header from upstream, client: 88.6.126.170, server: _, request: "GET /login/ HTTP/2.0", upstream: "fastcgi://unix:/run/hestia-php.sock:", host: "host.decastro.group:8083", referrer: "https://forum.hestiacp.com/"
2024/10/16 15:48:45 [error] 802#0: *10 FastCGI sent in stderr: "PHP message: PHP Warning:  session_start(): open(/usr/local/hestia/data/sessions/sess_jvek3huefo0c1f0cerq4oj7o7v, O_RDWR) failed: Permission denied (13) in /usr/local/hestia/web/index.php on line 2; PHP message: PHP Warning:  session_start(): Failed to read session data: files (path: /usr/local/hestia/data/sessions) in /usr/local/hestia/web/index.php on line 2" while reading response header from upstream, client: 88.6.126.170, server: _, request: "GET / HTTP/2.0", upstream: "fastcgi://unix:/run/hestia-php.sock:", host: "host.decastro.group:8083"
2024/10/16 15:48:45 [error] 802#0: *10 FastCGI sent in stderr: "PHP message: PHP Warning:  session_start(): open(/usr/local/hestia/data/sessions/sess_jvek3huefo0c1f0cerq4oj7o7v, O_RDWR) failed: Permission denied (13) in /usr/local/hestia/web/inc/main.php on line 2; PHP message: PHP Warning:  session_start(): Failed to read session data: files (path: /usr/local/hestia/data/sessions) in /usr/local/hestia/web/inc/main.php on line 2; PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning:  foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning:  Undefined array key "RELEASE_BRANCH" in /usr/local/hestia/web/inc/main.php on line 105; PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning:  foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Fatal error:  Uncaught TypeError: in_array(): Argument #2 ($haystack) must be of type array, null given in /usr/local/hestia/web/login/index.php:436
Stack trace:
#1 {main}
2024/10/16 18:15:08 [error] 802#0: *15 FastCGI sent in stderr: "PHP message: PHP Warning:  session_start(): open(/usr/local/hestia/data/sessions/sess_jvek3huefo0c1f0cerq4oj7o7v, O_RDWR) failed: Permission denied (13) in /usr/local/hestia/web/inc/main.php on line 2; PHP message: PHP Warning:  session_start(): Failed to read session data: files (path: /usr/local/hestia/data/sessions) in /usr/local/hestia/web/inc/main.php on line 2; PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning:  foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning:  Undefined array key "RELEASE_BRANCH" in /usr/local/hestia/web/inc/main.php on line 105; PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning:  foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Fatal error:  Uncaught TypeError: in_array(): Argument #2 ($haystack) must be of type array, null given in /usr/local/hestia/web/login/index.php:436
Stack trace:
#1 {main}
2024/10/16 18:58:19 [error] 802#0: *18 FastCGI sent in stderr: "PHP message: PHP Warning:  session_start(): open(/usr/local/hestia/data/sessions/sess_qejvbupvp5ghtqsrtu37ime0pf, O_RDWR) failed: Permission denied (13) in /usr/local/hestia/web/inc/main.php on line 2; PHP message: PHP Warning:  session_start(): Failed to read session data: files (path: /usr/local/hestia/data/sessions) in /usr/local/hestia/web/inc/main.php on line 2; PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning:  foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning:  Undefined array key "RELEASE_BRANCH" in /usr/local/hestia/web/inc/main.php on line 105; PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning:  foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Warning:  Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Fatal error:  Uncaught TypeError: in_array(): Argument #2 ($haystack) must be of type array, null given in /usr/local/hestia/web/login/index.php:436
Stack trace:
#1 {main}
  thrown in /usr/local/hestia/web/login/index.php on line 436" while reading response header from upstream, client: 86.80.172.6, server: _, request: "GET /login/ HTTP/2.0", upstream: "fastcgi://unix:/run/hestia-php.sock:", host: "host.decastro.group:8083", referrer: "https://forum.hestiacp.com/"
Execute this as root and try again::
chown -R admin:admin /usr/local/hestia/data/sessions
issue not solve
namei -mo /usr/local/hestia/data/sessions
ls -l /run/hestia-php.sock
df -h
root@host:~# namei -mo /usr/local/hestia/data/sessions
df -h
f: /usr/local/hestia/data/sessions
 drwxr-xr-x root  root  /
 drwxr-xr-x root  root  usr
 drwxr-xr-x root  root  local
 drwxr-xr-x root  admin hestia
 drwxr-xr-x root  admin data
 drwxr-xr-x admin admin sessions
srw-rw---- 1 admin admin 0 Oct 17 04:20 /run/hestia-php.sock
Filesystem      Size  Used Avail Use% Mounted on
tmpfs           794M  1.5M  793M   1% /run
/dev/sda1        97G   24G   74G  24% /
tmpfs           3.9G  1.2M  3.9G   1% /dev/shm
tmpfs           5.0M     0  5.0M   0% /run/lock
/dev/sda15      105M  6.1M   99M   6% /boot/efi
tmpfs           794M  8.0K  794M   1% /run/user/0
root@host:~#
The groups are not the ones Hestia configures, also, the perms are not the right ones. Did you modify them manually?
rm -f /usr/local/hestia/data/sessions/*
chmod 770 /usr/local/hestia/data/sessions/
Execute done
https://host.decastro.group:8083/fm/
Folder not writable: /private/logs/
Oops! Something went wrong.
The server encountered an internal error or misconfiguration and was unable to complete your request.
Error Code: 500
Check again the logs.
I ask the question again. Did you modify perms/owner/group manually on /usr/local/hestia/?
yes. by mistake i run command to change owner
root /
now everything fixed. expect Control Panel
Backup current perms:
getfacl -pR /usr/local/hestia/ > /root/hestia_saved_perms
Change these perms:
chown -R root:root /usr/local/hestia/
chown -R admin:admin /usr/local/hestia/web/fm/private
chown -R admin:admin /usr/local/hestia/web/fm/repository
chown admin:root /usr/local/hestia/data/keys
chown admin:root /usr/local/hestia/nginx/client_body_temp
chown admin:root /usr/local/hestia/nginx/fastcgi_temp
chown admin:root /usr/local/hestia/nginx/proxy_temp
chown admin:root /usr/local/hestia/nginx/scgi_temp
chown admin:root /usr/local/hestia/nginx/uwsgi_temp
chown Debian-exim:mail /usr/local/hestia/ssl/certificate.crt
chown Debian-exim:mail /usr/local/hestia/ssl/certificate.key
chmod 644 /usr/local/hestia/web/fm/private/logs/app.log
chmod 660 /usr/local/hestia/ssl/certificate.crt
chmod 660 /usr/local/hestia/ssl/certificate.key
chmod 700 /usr/local/hestia/nginx/client_body_temp
chmod 700 /usr/local/hestia/nginx/fastcgi_temp
chmod 700 /usr/local/hestia/nginx/proxy_temp
chmod 700 /usr/local/hestia/nginx/scgi_temp
chmod 700 /usr/local/hestia/nginx/uwsgi_temp
chmod 750 /usr/local/hestia/data/keys
chmod 755 /usr/local/hestia/web/fm/private
chmod 755 /usr/local/hestia/web/fm/repository
Restart hestia and try again:
systemctl restart hestia
Same as OLD
File manager section working
root@host:~# getfacl -pR /usr/local/hestia/ > /root/hestia_saved_perms
root@host:~# chown -R root:root /usr/local/hestia/
chown -R admichown -R root:root /usr/local/hestia/ns
chown -R admin:admin /usr/local/hestia/data/sessionse
chown -R admin:admin /usr/local/hestia/web/fm/privateory
chown admin:root /usr/local/hestia/data/keysent_body_temp
chown admin:root /usr/local/hestia/nginx/scgi_tempp
chown admin:root /usr/local/hestia/nginx/uwsgi_tempicate.crt
chmod 660 /usr/local/hestia/ssl/certificate.keyemp
chmod 700 /usr/local/hestia/nginx/scgi_tempp
chmod 750 /usr/local/hestia/data/keysivate
chmod 755 /usr/local/hestia/web/fm/privateory
chown: cannot access ‘/usr/local/hestia/data/keys’: No such file or directory
chmod: cannot access ‘/usr/local/hestia/web/fm/private/logs/app.log’: No such file or directory
chmod: cannot access ‘/usr/local/hestia/data/keys’: No such file or directory
root@host:~# systemctl restart hestia
root@host:~#
Show the error in logs
2024/10/17 04:20:04 [error] 43702#0: *9 FastCGI sent in stderr: “PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning: Undefined array key “RELEASE_BRANCH” in /usr/local/hestia/web/inc/main.php on line 105; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Fatal error: Uncaught TypeError: in_array(): Argument #2 ($haystack) must be of type array, null given in /usr/local/hestia/web/login/index.php:436
Stack trace:
#1 {main}
thrown in /usr/local/hestia/web/login/index.php on line 436” while reading response header from upstream, client: 103.239.252.41, server: _, request: “GET /login/ HTTP/2.0”, upstream: “fastcgi://unix:/run/hestia-php.sock:”, host: “host.decastro.group:8083”, referrer: “https://forum.hestiacp.com/”
2024/10/17 04:20:14 [error] 43702#0: *12 FastCGI sent in stderr: “PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning: Undefined array key “RELEASE_BRANCH” in /usr/local/hestia/web/inc/main.php on line 105; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Fatal error: Uncaught TypeError: in_array(): Argument #2 ($haystack) must be of type array, null given in /usr/local/hestia/web/login/index.php:436
Stack trace:
#1 {main}
2024/10/17 04:21:49 [error] 47573#0: *1 FastCGI sent in stderr: “PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning: Undefined array key “RELEASE_BRANCH” in /usr/local/hestia/web/inc/main.php on line 105; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Fatal error: Uncaught TypeError: in_array(): Argument #2 ($haystack) must be of type array, null given in /usr/local/hestia/web/login/index.php:436
Stack trace:
#1 {main}
2024/10/17 04:51:41 [error] 47573#0: *5 FastCGI sent in stderr: “PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning: Undefined array key “RELEASE_BRANCH” in /usr/local/hestia/web/inc/main.php on line 105; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Fatal error: Uncaught TypeError: in_array(): Argument #2 ($haystack) must be of type array, null given in /usr/local/hestia/web/login/index.php:436
Stack trace:
#1 {main}
2024/10/17 04:52:24 [error] 56092#0: *1 FastCGI sent in stderr: “PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning: Undefined array key “RELEASE_BRANCH” in /usr/local/hestia/web/inc/main.php on line 105; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Fatal error: Uncaught TypeError: in_array(): Argument #2 ($haystack) must be of type array, null given in /usr/local/hestia/web/login/index.php:436
Stack trace:
#1 {main}
2024/10/17 04:53:26 [error] 56092#0: *6 FastCGI sent in stderr: “PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning: Undefined array key “RELEASE_BRANCH” in /usr/local/hestia/web/inc/main.php on line 105; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Fatal error: Uncaught TypeError: in_array(): Argument #2 ($haystack) must be of type array, null given in /usr/local/hestia/web/login/index.php:436
Stack trace:
#1 {main}
thrown in /usr/local/hestia/web/login/index.php on line 436” while reading response header from upstream, client: 88.6.126.170, server: _, request: “GET /login/ HTTP/2.0”, upstream: “fastcgi://unix:/run/hestia-php.sock:”, host: “host.decastro.group:8083”, referrer: “https://forum.hestiacp.com/”
2024/10/17 05:43:47 [error] 56092#0: *9 FastCGI sent in stderr: “PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning: Undefined array key “RELEASE_BRANCH” in /usr/local/hestia/web/inc/main.php on line 105; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Fatal error: Uncaught TypeError: in_array(): Argument #2 ($haystack) must be of type array, null given in /usr/local/hestia/web/login/index.php:436
Stack trace:
#1 {main}
2024/10/17 05:50:22 [error] 56092#0: *11 FastCGI sent in stderr: “PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning: Undefined array key “RELEASE_BRANCH” in /usr/local/hestia/web/inc/main.php on line 105; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Fatal error: Uncaught TypeError: in_array(): Argument #2 ($haystack) must be of type array, null given in /usr/local/hestia/web/login/index.php:436
Stack trace:
#1 {main}
2024/10/17 05:50:28 [error] 56092#0: *13 FastCGI sent in stderr: “PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning: Undefined array key “RELEASE_BRANCH” in /usr/local/hestia/web/inc/main.php on line 105; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Fatal error: Uncaught TypeError: in_array(): Argument #2 ($haystack) must be of type array, null given in /usr/local/hestia/web/login/index.php:436
Stack trace:
#1 {main}
2024/10/17 06:10:48 [error] 56092#0: *15 FastCGI sent in stderr: “PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning: Undefined array key “RELEASE_BRANCH” in /usr/local/hestia/web/inc/main.php on line 105; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Fatal error: Uncaught TypeError: in_array(): Argument #2 ($haystack) must be of type array, null given in /usr/local/hestia/web/login/index.php:436
Stack trace:
#1 {main}
2024/10/17 06:40:11 [error] 85268#0: *5 FastCGI sent in stderr: “PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning: Undefined array key “RELEASE_BRANCH” in /usr/local/hestia/web/inc/main.php on line 105; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Fatal error: Uncaught TypeError: in_array(): Argument #2 ($haystack) must be of type array, null given in /usr/local/hestia/web/login/index.php:436
Stack trace:
#1 {main}
2024/10/17 06:43:32 [error] 85268#0: *8 FastCGI sent in stderr: "PHP message: PHP Warning: Undefined variable $v_user in /usr/local/hestia/web/fm/configuration.php on line 78; PHP message: PHP Warning: Undefined variable $v_user in /usr/local/hestia/web/fm/configuration.php on line 81; PHP message: PHP Warning: Undefined variable $v_user in /usr/local/hestia/web/fm/configuration.php on line 88; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/fm/configuration.php on line 94; PHP message: PHP Warning: Undefined variable $v_user in /usr/local/hestia/web/fm/configuration.php on line 111; PHP message: PHP Warning: Undefined variable $v_user in /usr/local/hestia/web/fm/configuration.php on line 114; PHP message: PHP Warning: Undefined variable $v_user in /usr/local/hestia/web/fm/configuration.php on line 120; PHP message: PHP Warning: Undefined variable $v_user in /usr/local/hestia/web/fm/configuration.php on line 121; PHP message: PHP Warning: Undefined variable $v_user in /usr/local/hestia/web/fm/backend/Services/Auth/Adapters/HestiaAuth.php on line 46; PHP message: PHP Fatal error: Uncaught TypeError: Hestiacp\quoteshellarg\quoteshellarg(): Argument #1 ($arg) must be of type string, null given, called in /usr/local/hestia/web/fm/backend/Services/Auth/Adapters/HestiaAuth.php on line 55 and defined in /usr/local/hestia/web/fm/vendor/hestiacp/phpquoteshellarg/src/Hestiacp/quoteshellarg/quoteshellarg.php:14
Stack trace:
#0 /usr/local/hestia/web/fm/backend/Services/Auth/Adapters/HestiaAuth.php(55): Hestiacp\quoteshellarg\quoteshellarg()
#1 /usr/local/hestia/web/fm/backend/Services/Router/Router.php(33): Filegator\Services\Auth\Adapters\HestiaAuth->user()
#2 /usr/local/hestia/web/fm/vendor/php-di/php-di/src/Definition/Resolver/ObjectCreator.php(143): Filegator\Services\Router\Router->__construct()
#3 /usr/local/hestia/web/fm/vendor/php-di/php-di/src/Definition/Resolver/ObjectCreator.php(71): DI\Definition\Resolver\ObjectCreator->createInstance()
#4 /usr/loc
2024/10/17 06:43:33 [error] 85268#0: *8 FastCGI sent in stderr: “PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning: Undefined array key “RELEASE_BRANCH” in /usr/local/hestia/web/inc/main.php on line 105; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Fatal error: Uncaught TypeError: in_array(): Argument #2 ($haystack) must be of type array, null given in /usr/local/hestia/web/login/index.php:436
Stack trace:
#1 {main}
thrown in /usr/local/hestia/web/login/index.php on line 436” while reading response header from upstream, client: 103.239.252.41, server: _, request: “GET /login/ HTTP/2.0”, upstream: “fastcgi://unix:/run/hestia-php.sock:”, host: “host.decastro.group:8083”, referrer: “https://host.decastro.group:8083/fm/”
2024/10/17 06:44:11 [error] 85268#0: *12 FastCGI sent in stderr: “PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning: Undefined array key “RELEASE_BRANCH” in /usr/local/hestia/web/inc/main.php on line 105; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Fatal error: Uncaught TypeError: in_array(): Argument #2 ($haystack) must be of type array, null given in /usr/local/hestia/web/login/index.php:436
Stack trace:
#1 {main}
#1 {main}
thrown in /usr/local/hestia/web/login/index.php on line 436" while reading response header from upstream, client: 86.80.172.6, server: _, request: “GET /login/ HTTP/2.0”, upstream: “fastcgi://unix:/run/hestia-php.sock:”, host: “host.decastro.group:8083”, referrer: “https://forum.hestiacp.com/”
2024/10/17 02:19:04 [error] 802#0: *21 FastCGI sent in stderr: “PHP message: PHP Warning: session_start(): open(/usr/local/hestia/data/sessions/sess_ai6h78aha69h7cpv7anf31dbrf, O_RDWR) failed: Permission denied (13) in /usr/local/hestia/web/index.php on line 2; PHP message: PHP Warning: session_start(): Failed to read session data: files (path: /usr/local/hestia/data/sessions) in /usr/local/hestia/web/index.php on line 2” while reading response header from upstream, client: 103.131.80.30, server: _, request: “GET / HTTP/2.0”, upstream: “fastcgi://unix:/run/hestia-php.sock:”, host: “host.decastro.group:8083”
2024/10/17 02:19:05 [error] 802#0: *21 FastCGI sent in stderr: “PHP message: PHP Warning: session_start(): open(/usr/local/hestia/data/sessions/sess_ai6h78aha69h7cpv7anf31dbrf, O_RDWR) failed: Permission denied (13) in /usr/local/hestia/web/inc/main.php on line 2; PHP message: PHP Warning: session_start(): Failed to read session data: files (path: /usr/local/hestia/data/sessions) in /usr/local/hestia/web/inc/main.php on line 2; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning: Undefined array key “RELEASE_BRANCH” in /usr/local/hestia/web/inc/main.php on line 105; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Fatal error: Uncaught TypeError: in_array(): Argument #2 ($haystack) must be of type array, null given in /usr/local/hestia/web/login/index.php:436
Stack trace:
#1 {main}
thrown in /usr/local/hestia/web/login/index.php on line 436” while reading response header from upstream, client: 103.131.80.30, server: _, request: “GET /login/ HTTP/2.0”, upstream: “fastcgi://unix:/run/hestia-php.sock:”, host: “host.decastro.group:8083”
2024/10/17 02:20:24 [error] 802#0: *28 FastCGI sent in stderr: “PHP message: PHP Warning: session_start(): open(/usr/local/hestia/data/sessions/sess_dvkqs0b6po1pbaa36f09fvugiv, O_RDWR) failed: Permission denied (13) in /usr/local/hestia/web/inc/main.php on line 2; PHP message: PHP Warning: session_start(): Failed to read session data: files (path: /usr/local/hestia/data/sessions) in /usr/local/hestia/web/inc/main.php on line 2; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning: Undefined array key “RELEASE_BRANCH” in /usr/local/hestia/web/inc/main.php on line 105; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Fatal error: Uncaught TypeError: in_array(): Argument #2 ($haystack) must be of type array, null given in /usr/local/hestia/web/login/index.php:436
Stack trace:
#1 {main}
2024/10/17 02:27:33 [error] 802#0: *30 FastCGI sent in stderr: “PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning: Undefined array key “RELEASE_BRANCH” in /usr/local/hestia/web/inc/main.php on line 105; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Fatal error: Uncaught TypeError: in_array(): Argument #2 ($haystack) must be of type array, null given in /usr/local/hestia/web/login/index.php:436
Stack trace:
#1 {main}
2024/10/17 02:27:35 [error] 802#0: *30 FastCGI sent in stderr: “PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning: Undefined array key “RELEASE_BRANCH” in /usr/local/hestia/web/inc/main.php on line 105; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Fatal error: Uncaught TypeError: in_array(): Argument #2 ($haystack) must be of type array, null given in /usr/local/hestia/web/login/index.php:436
Stack trace:
#1 {main}
Stack trace:
#1 {main}
2024/10/17 02:27:36 [error] 802#0: *30 FastCGI sent in stderr: “PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning: Undefined array key “RELEASE_BRANCH” in /usr/local/hestia/web/inc/main.php on line 105; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Fatal error: Uncaught TypeError: in_array(): Argument #2 ($haystack) must be of type array, null given in /usr/local/hestia/web/login/index.php:436
Stack trace:
#1 {main}
2024/10/17 02:42:32 [error] 41659#0: *1 FastCGI sent in stderr: “PHP message: PHP Warning: session_start(): open(/usr/local/hestia/data/sessions/sess_s84aml7r6vr6d1qje9gbdegiio, O_RDWR) failed: Permission denied (13) in /usr/local/hestia/web/index.php on line 2; PHP message: PHP Warning: session_start(): Failed to read session data: files (path: /usr/local/hestia/data/sessions) in /usr/local/hestia/web/index.php on line 2” while reading response header from upstream, client: 103.131.80.30, server: _, request: “GET / HTTP/2.0”, upstream: “fastcgi://unix:/run/hestia-php.sock:”, host: “host.decastro.group:8083”
2024/10/17 02:42:32 [error] 41659#0: *1 FastCGI sent in stderr: “PHP message: PHP Warning: session_start(): open(/usr/local/hestia/data/sessions/sess_s84aml7r6vr6d1qje9gbdegiio, O_RDWR) failed: Permission denied (13) in /usr/local/hestia/web/inc/main.php on line 2; PHP message: PHP Warning: session_start(): Failed to read session data: files (path: /usr/local/hestia/data/sessions) in /usr/local/hestia/web/inc/main.php on line 2; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning: Undefined array key “RELEASE_BRANCH” in /usr/local/hestia/web/inc/main.php on line 105; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Fatal error: Uncaught TypeError: in_array(): Argument #2 ($haystack) must be of type array, null given in /usr/local/hestia/web/login/index.php:436
Stack trace:
#1 {main}
2024/10/17 02:42:33 [error] 41659#0: *1 FastCGI sent in stderr: “PHP message: PHP Warning: session_start(): open(/usr/local/hestia/data/sessions/sess_s84aml7r6vr6d1qje9gbdegiio, O_RDWR) failed: Permission denied (13) in /usr/local/hestia/web/inc/main.php on line 2; PHP message: PHP Warning: session_start(): Failed to read session data: files (path: /usr/local/hestia/data/sessions) in /usr/local/hestia/web/inc/main.php on line 2; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning: Undefined array key “RELEASE_BRANCH” in /usr/local/hestia/web/inc/main.php on line 105; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Fatal error: Uncaught TypeError: in_array(): Argument #2 ($haystack) must be of type array, null given in /usr/local/hestia/web/login/index.php:436
Stack trace:
#1 {main}
2024/10/17 02:42:35 [error] 41659#0: *1 FastCGI sent in stderr: “PHP message: PHP Warning: session_start(): open(/usr/local/hestia/data/sessions/sess_s84aml7r6vr6d1qje9gbdegiio, O_RDWR) failed: Permission denied (13) in /usr/local/hestia/web/inc/main.php on line 2; PHP message: PHP Warning: session_start(): Failed to read session data: files (path: /usr/local/hestia/data/sessions) in /usr/local/hestia/web/inc/main.php on line 2; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning: Undefined array key “RELEASE_BRANCH” in /usr/local/hestia/web/inc/main.php on line 105; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Fatal error: Uncaught TypeError: in_array(): Argument #2 ($haystack) must be of type array, null given in /usr/local/hestia/web/login/index.php:436
Stack trace:
#1 {main}
2024/10/17 02:46:56 [error] 43702#0: *1 FastCGI sent in stderr: “PHP message: PHP Warning: session_start(): open(/usr/local/hestia/data/sessions/sess_s84aml7r6vr6d1qje9gbdegiio, O_RDWR) failed: Permission denied (13) in /usr/local/hestia/web/inc/main.php on line 2; PHP message: PHP Warning: session_start(): Failed to read session data: files (path: /usr/local/hestia/data/sessions) in /usr/local/hestia/web/inc/main.php on line 2; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning: Undefined array key “RELEASE_BRANCH” in /usr/local/hestia/web/inc/main.php on line 105; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Fatal error: Uncaught TypeError: in_array(): Argument #2 ($haystack) must be of type array, null given in /usr/local/hestia/web/login/index.php:436
Stack trace:
#1 {main}
2024/10/17 03:24:18 [error] 43702#0: *6 FastCGI sent in stderr: “PHP message: PHP Warning: session_start(): open(/usr/local/hestia/data/sessions/sess_1402jtf2j4fl8qpp1leteot64i, O_RDWR) failed: Permission denied (13) in /usr/local/hestia/web/inc/main.php on line 2; PHP message: PHP Warning: session_start(): Failed to read session data: files (path: /usr/local/hestia/data/sessions) in /usr/local/hestia/web/inc/main.php on line 2; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning: Undefined array key “RELEASE_BRANCH” in /usr/local/hestia/web/inc/main.php on line 105; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/inc/main.php on line 527; PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/inc/main.php on line 528; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Warning: Trying to access array offset on value of type null in /usr/local/hestia/web/login/index.php on line 431; PHP message: PHP Fatal error: Uncaught TypeError: in_array(): Argument #2 ($haystack) must be of type array, null given in /usr/local/hestia/web/login/index.php:436
Stack trace:
#1 {main}
thrown in /usr/local/hestia/web/login/index.php on line 436” while reading response header from upstream, client: 181.203.70.110, server: _, request: “GET /login/ HTTP/2.0”, upstream: “fastcgi://unix:/run/hestia-php.sock:”, host: “host.decastro.group:8083”, referrer: “https://forum.hestiacp.com/”
v-list-sys-config json
v-list-sys-languages json
root@host:~# v-list-sys-config json
                "config": {
                        "WEB_SYSTEM": "apache2",
                        "WEB_RGROUPS": "www-data",
                        "WEB_PORT": "8080",
                        "WEB_SSL": "mod_ssl",
                        "WEB_SSL_PORT": "8443",
                        "WEB_BACKEND": "php-fpm",
                        "PROXY_SYSTEM": "nginx",
                        "PROXY_PORT": "80",
                        "PROXY_SSL_PORT": "443",
                        "FTP_SYSTEM": "vsftpd",
                        "MAIL_SYSTEM": "exim4",
                        "IMAP_SYSTEM": "dovecot",
                        "ANTIVIRUS_SYSTEM": "clamav-daemon",
                        "ANTISPAM_SYSTEM": "spamassassin",
                        "DB_SYSTEM": "mysql",
                        "DNS_SYSTEM": "bind9",
                        "DNS_CLUSTER": "",
                        "DNS_CLUSTER_SYSTEM": "hestia",
                        "SUPPORT_DNSSEC": "yes",
                        "STATS_SYSTEM": "awstats",
                        "BACKUP_SYSTEM": "ftp",
                        "CRON_SYSTEM": "cron",
                        "DISK_QUOTA": "no",
                        "FIREWALL_SYSTEM": "iptables",
                        "FIREWALL_EXTENSION": "fail2ban",
                        "FILE_MANAGER": "true",
                        "REPOSITORY": "",
                        "VERSION": "1.8.12",
                        "RELEASE_BRANCH": "release",
                        "UPGRADE_SEND_EMAIL": "true",
                        "UPGRADE_SEND_EMAIL_LOG": "false",
                        "SMTP_RELAY": "",
                        "SMTP_RELAY_HOST": "",
                        "SMTP_RELAY_PORT": "",
                        "SMTP_RELAY_USER": "",
                        "DEMO_MODE": "",
                        "THEME": "dark",
                        "LANGUAGE": "en",
                        "BACKUP_GZIP": "4",
                        "BACKUP": "/backup",
                        "BACKUP_MODE": "zstd",
                        "WEBMAIL_ALIAS": "webmail",
                        "WEBMAIL_SYSTEM": "roundcube",
                        "DB_PMA_ALIAS": "phpmyadmin",
                        "DB_PGA_ALIAS": "",
                        "LOGIN_STYLE": "default",
                        "INACTIVE_SESSION_TIMEOUT": "60",
                        "PHPMYADMIN_KEY": "",
                        "ENFORCE_SUBDOMAIN_OWNERSHIP": "yes",
                        "DEBUG_MODE": "false",
                        "API": "yes",
                        "API_SYSTEM": "1",
                        "API_ALLOWED_IP": "",
                        "UPDATE_AVAILABLE": "",
                        "PLUGIN_APP_INSTALLER": "true",
                        "PLUGIN_FILE_MANAGER": "",
                        "POLICY_SYSTEM_ENABLE_BACON": "false",
                        "POLICY_SYSTEM_PROTECTED_ADMIN": "yes",
                        "POLICY_SYSTEM_HIDE_ADMIN": "no",
                        "POLICY_SYSTEM_HIDE_SERVICES": "no",
                        "POLICY_SYSTEM_PASSWORD_RESET": "no",
                        "POLICY_USER_VIEW_SUSPENDED": "false",
                        "POLICY_BACKUP_SUSPENDED_USERS": "no",
                        "POLICY_USER_EDIT_DETAILS": "yes",
                        "POLICY_USER_EDIT_WEB_TEMPLATES": "yes",
                        "POLICY_USER_EDIT_DNS_TEMPLATES": "yes",
                        "POLICY_USER_DELETE_LOGS": "yes",
                        "POLICY_USER_VIEW_LOGS": "yes",
                        "POLICY_USER_CHANGE_THEME": "yes",
                        "POLICY_CSRF_STRICTNESS": "1",
                        "POLICY_SYNC_SKELETON": "yes",
                        "POLICY_SYNC_ERROR_DOCUMENTS": "yes",
                        "USE_SERVER_SMTP": "false",
                        "SERVER_SMTP_HOST": "",
                        "SERVER_SMTP_PORT": "",
                        "SERVER_SMTP_SECURITY": "",
                        "SERVER_SMTP_USER": "",
                        "SERVER_SMTP_PASSWD": "",
                        "SERVER_SMTP_ADDR": "",
                        "DISABLE_IP_CHECK": "no",
                        "FROM_NAME": "DCG Server",
                        "FROM_EMAIL": "[email protected]",
                        "APP_NAME": "De Castro Group",
                        "TITLE": "{{page}} - De Castro Group",
                        "SUBJECT_EMAIL": "{{subject}}",
                        "HIDE_DOCS": "no"
        "en",
        "ar",
        "az",
        "bg",
        "bn",
        "bs",
        "ca",
        "cs",
        "da",
        "de",
        "el",
        "es",
        "fa",
        "fi",
        "fr",
        "hr",
        "hu",
        "id",
        "it",
        "ja",
        "ka",
        "ko",
        "ku",
        "nl",
        "no",
        "pl",
        "pt-br",
        "pt",
        "ro",
        "ru",
        "sk",
        "sq",
        "sr",
        "sv",
        "th",
        "tr",
        "uk",
        "ur",
        "vi",
        "zh-cn",
        "zh-tw"
root@host:~#
I see no obvious problem…
Try to reinstall hestia package.
apt install --reinstall hestia
