Hi, I checked the box “enable 2fa” then clicked on save.
I don’t see a QR code.
You must click on Save button to see the QR code.
That’s strange, when you select Enable two-factor authentication
and click Save, you should see something like this:
Try to add it using command line:
v-add-user-2fa YourUser
And check again in your user profile whether you can see the QR
As I said in your other post, the problem is the connectivity with external domains, so you can’t get the QR code because it is created calling an external site.
