Unable to get SSL for web domain in Hestia CP
I was trying to create website on gcloud using free tier.
I am trying to get ssl for web domain which I added in hestia cp. but getting this error message
Error: Let’s Encrypt validation status 400 (hbkproperties.in). Details: 400:“216.239.32.109: Fetching http://www.hbkproperties.in/.well-known/acme-challenge/zbe-YukT0yGaUxYT2TbUNBWYIN4thsyGM1G56hzqCq4: Timeout during connect (likely firewall problem)”
can someone help me out in this? I am not a developer.
DNS is not proper setup contact your DNS provider
I think I have made mistake while adding dns records.
when I was adding cname record. it was not accepting so added “ns-cloud-d1.googledomains.com” this to it.
can you suggest me what changes should I make there?
please be aware of Please read this, before you start!.
You should clearly know what dns is, including the default records when you want to use hestia. We cant teach basics here.
A record with the server ip or hbkproperties.in
Thank you for the solution and really appreciate the great response on my topic.
I deleted the instance. then reconfigured the dns records and recreated everything.
this time everything worked smoothly.
Thank You
