Unable to Login Admin Panel
When trying to login to the panel, my user name and password are accepted however the screen refreshes and loops me back to login again. Confirmed in the auth logs that credentials are no the issue how I am seeing this on the Nginx side and I have no clue how to fix. Hope someone can help?
0.0.1:8083/login/"
2022/08/10 21:13:56 [error] 181424#0: *17 FastCGI sent in stderr: “PHP message: PHP Warning: session_start(): open(/usr/local/hestia/data/sessions/sess_685piel4o3gurjnj41adnth6ah, O_RDWR) failed: Permission denied (13) in /usr/local/hestia/web/inc/main.php on line 2PHP message: PHP Warning: session_start(): Failed to read session data: files (path: /usr/local/hestia/data/sessions) in /usr/local/hestia/web/inc/main.php on line 2” while reading response header from upstream, client: 127.0.0.1, server: _, request: “POST /login/ HTTP/1.1”, upstream: “fastcgi://unix:/var/run/hestia-php.sock:”, host: “127.0.0.1:8083”, referrer: “https://127.0.0.1:8083/login/”
2022/08/10 21:14:00 [error] 181424#0: *17 FastCGI sent in stderr: “PHP message: PHP Warning: session_start(): open(/usr/local/hestia/data/sessions/sess_685piel4o3gurjnj41adnth6ah, O_RDWR) failed: Permission denied (13) in /usr/local/hestia/web/inc/main.php on line 2PHP message: PHP Warning: session_start(): Failed to read session data: files (path: /usr/local/hestia/data/sessions) in /usr/local/hestia/web/inc/main.php on line 2” while reading response header from upstream, client: 127.0.0.1, server: _, request: “POST /login/ HTTP/1.1”, upstream: “fastcgi://unix:/var/run/hestia-php.sock:”, host: “127.0.0.1:8083”, referrer: “https://127.0.0.1:8083/login/”
2022/08/10 21:14:00 [error] 181424#0: *17 FastCGI sent in stderr: “PHP message: PHP Warning: Array to string conversion in /usr/local/hestia/web/templates/pages/debug_panel.html on line 11” while reading upstream, client: 127.0.0.1, server: _, request: “POST /login/ HTTP/1.1”, upstream: “fastcgi://unix:/var/run/hestia-php.sock:”, host: “127.0.0.1:8083”, referrer: “https://127.0.0.1:8083/login/”
2022/08/10 21:14:02 [error] 181424#0: *17 FastCGI sent in stderr: “PHP message: PHP Warning: session_start(): open(/usr/local/hestia/data/sessions/sess_685piel4o3gurjnj41adnth6ah, O_RDWR) failed: Permission denied (13) in /usr/local/hestia/web/inc/main.php on line 2PHP message: PHP Warning: session_start(): Failed to read session data: files (path: /usr/local/hestia/data/sessions) in /usr/local/hestia/web/inc/main.php on line 2” while reading response header from upstream, client: 127.0.0.1, server: _, request: “POST /login/ HTTP/1.1”, upstream: “fastcgi://unix:/var/run/hestia-php.sock:”, host: “127.0.0.1:8083”, referrer: “https://127.0.0.1:8083/login/”
2022/08/10 22:05:29 [error] 330524#0: OCSP response not successful (6: unauthorized) while requesting certificate status, responder: r3.o.lencr.org, peer: 104.76.210.88:80, certificate: “/usr/local/hestia/ssl/certificate.crt”
2022/08/10 22:05:30 [error] 330524#0: *1 FastCGI sent in stderr: “PHP message: PHP Warning: session_start(): open(/usr/local/hestia/data/sessions/sess_685piel4o3gurjnj41adnth6ah, O_RDWR) failed: Permission denied (13) in /usr/local/hestia/web/inc/main.php on line 2PHP message: PHP Warning: session_start(): Failed to read session data: files (path: /usr/local/hestia/data/sessions) in /usr/local/hestia/web/inc/main.php on line 2” while reading response header from upstream, client: 127.0.0.1, server: _, request: “POST /login/ HTTP/1.1”, upstream: “fastcgi://unix:/var/run/hestia-php.sock:”, host: “127.0.0.1:8083”, referrer: “https://127.0.0.1:8083/login/”
2022/08/10 22:05:30 [error] 330524#0: *1 FastCGI sent in stderr: “PHP message: PHP Warning: Array to string conversion in /usr/local/hestia/web/templates/pages/debug_panel.html on line 11” while reading upstream, client: 127.0.0.1, server: _, request: “POST /login/ HTTP/1.1”, upstream: “fastcgi://unix:/var/run/hestia-php.sock:”, host: “127.0.0.1:8083”, referrer: “https://127.0.0.1:8083/login/”
2022/08/10 22:05:38 [error] 330524#0: *1 FastCGI sent in stderr: “PHP message: PHP Warning: session_start(): open(/usr/local/hestia/data/sessions/sess_685piel4o3gurjnj41adnth6ah, O_RDWR) failed: Permission denied (13) in /usr/local/hestia/web/inc/main.php on line 2PHP message: PHP Warning: session_start(): Failed to read session data: files (path: /usr/local/hestia/data/sessions) in /usr/local/hestia/web/inc/main.php on line 2” while reading response header from upstream, client: 127.0.0.1, server: _, request: “POST /login/ HTTP/1.1”, upstream: “fastcgi://unix:/var/run/hestia-php.sock:”, host: “127.0.0.1:8083”, referrer: “https://127.0.0.1:8083/login/”
2022/08/10 22:12:46 [error] 330524#0: OCSP response not successful (6: unauthorized) while requesting certificate status, responder: r3.o.lencr.org, peer: 104.76.210.76:80, certificate: “/usr/local/hestia/ssl/certificate.crt”
2022/08/10 22:12:47 [error] 330524#0: *10 FastCGI sent in stderr: “PHP message: PHP Warning: session_start(): open(/usr/local/hestia/data/sessions/sess_685piel4o3gurjnj41adnth6ah, O_RDWR) failed: Permission denied (13) in /usr/local/hestia/web/inc/main.php on line 2PHP message: PHP Warning: session_start(): Failed to read session data: files (path: /usr/local/hestia/data/sessions) in /usr/local/hestia/web/inc/main.php on line 2” while reading response header from upstream, client: 127.0.0.1, server: _, request: “POST /login/ HTTP/1.1”, upstream: “fastcgi://unix:/var/run/hestia-php.sock:”, host: “127.0.0.1:8083”, referrer: “https://127.0.0.1:8083/login/”
2022/08/10 22:12:47 [error] 330524#0: *10 FastCGI sent in stderr: “PHP message: PHP Warning: Array to string conversion in /usr/local/hestia/web/templates/pages/debug_panel.html on line 11” while reading upstream, client: 127.0.0.1, server: _, request: “POST /login/ HTTP/1.1”, upstream: “fastcgi://unix:/var/run/hestia-php.sock:”, host: “127.0.0.1:8083”, referrer: “https://127.0.0.1:8083/login/”
2022/08/10 22:12:51 [error] 330524#0: *10 FastCGI sent in stderr: “PHP message: PHP Warning: session_start(): open(/usr/local/hestia/data/sessions/sess_685piel4o3gurjnj41adnth6ah, O_RDWR) failed: Permission denied (13) in /usr/local/hestia/web/inc/main.php on line 2PHP message: PHP Warning: session_start(): Failed to read session data: files (path: /usr/local/hestia/data/sessions) in /usr/local/hestia/web/inc/main.php on line 2” while reading response header from upstream, client: 127.0.0.1, server: _, request: “POST /login/ HTTP/1.1”, upstream: “fastcgi://unix:/var/run/hestia-php.sock:”, host: “127.0.0.1:8083”, referrer: “https://127.0.0.1:8083/login/”
2022/08/10 22:17:04 [error] 330524#0: *19 FastCGI sent in stderr: “PHP message: PHP Warning: session_start(): open(/usr/local/hestia/data/sessions/sess_685piel4o3gurjnj41adnth6ah, O_RDWR) failed: Permission denied (13) in /usr/local/hestia/web/inc/main.php on line 2PHP message: PHP Warning: session_start(): Failed to read session data: files (path: /usr/local/hestia/data/sessions) in /usr/local/hestia/web/inc/main.php on line 2” while reading response header from upstream, client: 127.0.0.1, server: _, request: “POST /login/ HTTP/1.1”, upstream: “fastcgi://unix:/var/run/hestia-php.sock:”, host: “127.0.0.1:8083”, referrer: “https://127.0.0.1:8083/login/”
2022/08/10 22:17:04 [error] 330524#0: *19 FastCGI sent in stderr: “PHP message: PHP Warning: Array to string conversion in /usr/local/hestia/web/templates/pages/debug_panel.html on line 11” while reading upstream, client: 127.0.0.1, server: _, request: “POST /login/ HTTP/1.1”, upstream: “fastcgi://unix:/var/run/hestia-php.sock:”, host: “127.0.0.1:8083”, referrer: “https://127.0.0.1:8083/login/”
2022/08/10 22:17:09 [error] 330524#0: *19 FastCGI sent in stderr: “PHP message: PHP Warning: session_start(): open(/usr/local/hestia/data/sessions/sess_685piel4o3gurjnj41adnth6ah, O_RDWR) failed: Permission denied (13) in /usr/local/hestia/web/inc/main.php on line 2PHP message: PHP Warning: session_start(): Failed to read session data: files (path: /usr/local/hestia/data/sessions) in /usr/local/hestia/web/inc/main.php on line 2” while reading response header from upstream, client: 127.0.0.1, server: _, request: “POST /login/ HTTP/1.1”, upstream: “fastcgi://unix:/var/run/hestia-php.sock:”, host: “127.0.0.1:8083”, referrer: “https://127.0.0.1:8083/login/”
Permissions of the session folder looks wrong
What are the permissions of /var/log/hestia/data/sessions
You’re right, sorry I was trying figure out how to close this. It was ts sessions folder that needed to be changed to admin:admin.
