Unable to receive emails in webmail (roundcube), I am using Brevo for SMTP relay
Dear Friends,
I can send emails from my email address created on hestiacp for my domain and the brevo SMTP relay is used but I cannot receive the emails.
I sent an email to my gmail address and I can receive it and I replied using the same gmail account but I cannot receive the email.
I did this previously with other domains and they were working but now on a new domain it’s not working.
Please help…
Check /var/log/exim4/mainlog
Around the same time you replied on your email…
Where to check this one? I mean on hestiacp file manager or ubuntu or somewhere else?
I don’t know much about web hosting, please give some more details…
Using HestiaCP does not replace the need to know how to administer az Linux server.
However, since you asked nicely…
Login with ssh …
2024-02-04_02-44-31
“Failed to read config, exiting”
still cannot receive the email, please help…
tail -f -s0.1 /var/log/exim4/mainlog
2024-02-04_04-18-10
Got this bro…
I am getting this message every few hours in my gmail that says " The response from the remote server was:
550 Rejected because 209.85.222.169 is in a black list at zen.spamhaus.org Error: excess volume; https://check.spamhaus.org/returnc/vol/140.204.50.41/"
I am now following these instructions on the page. Am I right?
This solved my problem… Thank you so much @eris for your help buddy…
i used it too by chance i was here and it worked Nick
Use an SMTP relay . The IP is blacklisted not your domain…
Hi @msreddy,
Next time don’t remove it, just change the perms:
chown -R hestiamail:www-data /etc/roundcube/
find /etc/roundcube/ -type f -iname "*php" -exec chmod 640 {} \;
chown -R hestiamail:www-data /var/lib/roundcube/
chown -R hestiamail:www-data /var/log/roundcube/
As @eris said, spamhaus doesn’t block domains, only ips, anyways, the blacklisted ip shown in your log is not yours, is from gmail and that means that you are using a public resolver like 1.1.1.1 in your server to resolve dns queries and spamhaus doesn’t allow it.
Take a look to this Rejected because [ip] is in black list at zen.spamhaus.org
Or you can change your server to use other public resolver, as far as I know spamhaus doesn’t block google dns resolver 8.8.8.8 (at least not yet).
