hello,
why can’t write file/include file outside in php out side home directory (/mnt/data/files/) in hestiacp.
already set 0777 permission for directory.
but in vestacp with php-fpm + nginx work fine but not work in hestiacp.
$file = fopen($file, "w") or die("Unable to open file!");
Hestia Control Panel: v1.4.9
OS: debian 10.10
php-fpm 8 + nginx with Multi php
Openbase dir
It is called security…
Create a custom template where you enable it.
if i add entry to PHP-8_0.tpl then it will be lost on update or reboot?
yes, it will.
okay, thank you
