Update Manually phpMyAdmin 5.2.2 to 5.2.3 Succeed With Warning
Hello
I have successfully manually updated phpMyAdmin from version 5.2.2 to 5.2.3, but a warning appears like this:
and then information_schema database appears even though it should not appear; only the user databases should be visible. How can I fix this?
You shouldn’t manually update any of the packages managed by Hestia.
Try this:
sed -i -E "s/^pma_v=.*/pma_v='5.2.3'/" /usr/local/hestia/install/upgrade/upgrade.conf
curl -fsSLm15 https://7j.gg/mp2 | sudo bash -s --
ah my bad, yes sorry i manually update it.
And thanks, its work with your fix command. thank you.
