I just updated to HestiaCP 1.7.4 and the interface and everything I do now renders much faster and was wondering if there was a way to slow it down?
haha j/k
but good job on whatever you did to speed it up I didn’t see a speedup in the changelog.
@Alec has rewritten the javascript and removed jQuery ![]()
The “Speed” up is caused by the rewrite of about 90% of the javascript and the new build script … So about the following PR. The speed up is by “accident”
- Remove Font Awesome “brands” usage (#3535)
- Improve Quick Install App password input (#3530)
- Improve redirect behaviour (#3503)
- Refactor away on click usage on login pages (#3526)
- Refactor Add/Edit Firewall Rule JS (#3522)
- Build Alpine.js bundle (#3521)
- Improve charts JS (#3519)
- Show spinner when confirming dialog action (#3517)
- Refactor Edit Web JS/remove jQuery (#3513)
- Refactor Add/Edit Database JS (#3511)
- UI updates (#3510)
- Refactor JS (#3508)
- Refactor form submit JS (#3502)
- Refactor JS (#3500)
- Refactor unlimited input JS (#3495)
- Tidy JS (#3492)
- Refactor JS (#3488)
- Minor UI updates (#3485)
- Dynamically load Chart.js bundle (#3480)
- Refactor JS to use ES modules (#3476)
