Will my hestiacp break if I update/upgrade the outdated libraries as suggested by apt-update, apt-upgrade ?
Hello @g07u ,
That message doesn’t say that you need to update libraries, it says that some libraries have been already updated and those daemons/services are using the old libraries and must be restarted so they can use the updated libraries.
Cheers,
sahsanu
My bad, yes you’re right.
