Updating to 1.2.2 - error ssl not enabled
Hi, just updated to to 1.2.2 from 1.2.1 and got the error below, never had this on previous updates?
This process may take a few minutes, please wait…
[ * ] Backing up existing templates and configuration files…
[ ! ] Updating default web domain templates…
Error: SSL is not enabled
[ ! ] Hardening Vsftpd TLS configuration…
[ * ] Hardening APT repositories…
----- NGINX
----- MariaDB
thanks
If you have domains with out SSL enabled there is no issue
See
maybe we should rephrase that :slight_smile:
LMFTFY
Though, in this context, checking for HSTS, it really is an error :wink:
v-add-web-domain-ssl-hsts should not be called at all if the web domain does not have not ssl or hsts enabled. This looks like it could be a bug
