Upgradable phpmyadmin after VPS upgrade
After ‘apt update && apt upgrade && reboot’ my HestiaCP 1.8.8 on Debian 11 in Hetzner VPS:
# apt update
Hit:1 http://mirror.hetzner.de/debian/packages bullseye InRelease
Hit:2 http://deb.debian.org/debian bullseye InRelease
Get:3 http://deb.debian.org/debian-security bullseye-security InRelease [48.4 kB]
Get:4 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
Get:5 http://mirror.hetzner.de/debian/packages bullseye-updates InRelease [44.1 kB]
Get:6 http://mirror.hetzner.de/debian/packages bullseye-backports InRelease [49.0 kB]
Get:7 http://mirror.hetzner.de/debian/security bullseye-security InRelease [48.4 kB]
Hit:8 https://nginx.org/packages/mainline/debian bullseye InRelease
Hit:9 https://mirror.mva-n.net/mariadb/repo/10.6/debian bullseye InRelease
Hit:10 https://packages.sury.org/apache2 bullseye InRelease
Hit:11 https://packages.sury.org/php bullseye InRelease
Hit:12 https://apt.hestiacp.com bullseye InRelease
Fetched 234 kB in 2s (148 kB/s)
Reading package lists... Done
Building dependency tree... Done
1 package can be upgraded. Run 'apt list --upgradable' to see it.
# apt list --upgradable
Listing... Done
phpmyadmin/oldstable,oldstable 4:5.0.4+dfsg2-2+deb11u1 all [upgradable from: 4:4.6.6-5]
N: There is 1 additional version. Please use the '-a' switch to see it
# apt list --upgradable -a
Listing... Done
phpmyadmin/bullseye-backports 4:5.2.1+dfsg-1~bpo11+1 all
phpmyadmin/now 4:4.6.6-5 all [installed,upgradable to: 4:5.0.4+dfsg2-2+deb11u1]
# apt upgrade
Calculating upgrade... Done
The following packages were automatically installed and are no longer required:
  at libfl2 libreadline5 libzip5 linux-image-4.19.0-18-amd64 linux-image-5.10.0-11-amd64 linux-image-5.10.0-19-amd64 linux-image-5.10.0-9-amd64
  php8.0 php8.0-curl php8.0-imap php8.0-ldap php8.1 php8.1-apcu php8.1-curl php8.1-imap php8.1-ldap
Use 'apt autoremove' to remove them.
The following packages have been kept back:
  phpmyadmin
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
What should I do with that package? Thanks.
Just keep it as held back…
We download it now directly from upstream…
Is there a way to remove the phpmyadmin package completely from Apt (without uninstall) so that if the hold is accidentally removed, it doesn’t upgrade?
I’m not sure how it even got in there because I don’t recall ever installing it. All thought maybe I did?
Not I am aware of …
