I changed to PHP 8.4, I needed to change it several times in the web interface for it to be applied, but when removing PHP 8.3 I see error 500, can you help me?
you can try to remove 8.4. and then install 8.4
apt-get remove --purge php8.4-fpm
v-add-web-php 8.4
