Upgrade to 1.10 if I do not upgrade Ubuntu to 26
If I keep my Ubuntu at 24 at this moment and upgrade HestiaCP to 1.10. Do I need to do anything special or just install as usual HestiaCP update with apt upgrade?
I want to hold the OS upgrade until a bit later. I think 1.10 should still fully compatible with Ubuntu 24?
No, you don’t need to do anything special, just upgrade Hestia as usual.
Yes, it is. Just keep in mind that when you want to upgrade your OS to 26.04 you should follow a few steps.
got it thanks
