Upgrade to 1.3.2
I recently upgraded to 1.3.2 from 1.2.4 by running apt-get update && apt-get upgrade (root user) on ubuntu 18.04 and it prompted me to configure phpmyadmin and webserver again? Is this expected?
I ended up exiting the prompts and continuing the package updates but when I logged in to hestia control panel it was still at version 1.2.4 so I then I upgraded the 3 hestia packages through the hestia control panel GUI instead.
We don’t update phpmyadmin via apt but maybe check there is an package update in Ubuntu 18.04…
for me the same also from 1.2.4 to 1.3.2 on ubuntu 18.04 with the command sudo apt-get update && sudo apt-get dist-upgrade
i ran the phpmyadmin update though and everything is ok. hestiacp 1.3.2 is running fine thanks for that.
I don’t know if to open a new thread about it, but since I updated hestia to version 1.3.2 in ubuntu 18.04, I’m getting a notification to the mail that gives me this notice:
PHP Warning: PHP Startup: Unable to load dynamic library ‘php_pdo_sqlite.dll’ (tried: /usr/lib/php/20180731/php_pdo_sqlite.dll (/usr/lib/php/20180731/php_pdo_sqlite.dll: cannot open shared object file: No such file or directory), /usr/lib/php/20180731/php_pdo_sqlite.dll.so (/usr/lib/php/20180731/php_pdo_sqlite.dll.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
I imagine that deactivating the library will no longer give the warning, but what if it’s something critical to hestia?
I don’t think Hestia will install the pdo_sqlite
Don’t know if this Is done manually
