Upgrading Debian 10 Buster to Debian 11 Bullseye
Then I suppose right now phpMyAdmin doesn’t work, righ?
exactly, it doesn’t work
Execute again the script:
/usr/local/hestia/install/upgrade/manual/migrate_phpmyadmin.sh
To remove phpMyAdmin you will need use the root password. Password can be found in /usr/local/hestia/conf/mysql.conf
Would you like to continue? [y/n]y
[ * ] Backing up old configuration files…
cp: cannot stat ‘/var/lib/phpmyadmin/*’: No such file or directory
[ * ] Marking phpmyadmin as held in apt…
phpmyadmin set on hold.
[ * ] Removing old folders…
[ * ] Creating new folders…
[ * ] Installing phpMyAdmin version v5.2.1…
[ * ] Creating localhost configuration…
[ * ] Dropping database (could throw an error if successful)…
Thank you very much, and sorry for all the time you have spent helping me solve this problem.
Now if I upgrade to Debian 12, will I have the same problems or not?
You are welcome.
Who knows… :wink: Just in case, if you can, make a snapshot of your server.
What do you mean by this?
Usually, hosting providers allow to make a snapshot of your server, a backup of the entire server so if something goes wrong with an upgrade, you can always restore that snapshot.
Yes, that’s correct. I had already taken a snapshot before, and now I will take a new one with this update, thanks.
Debian 11 [bullseye] to Debian 12 [bookworm] upgrade process completed successfully
Again I’m having problems when doing apt update, now with Debian 12
Me puedes ayudar por favor:
apt update
Hit:1 Index of /debian bookworm InRelease
Hit:2 Index of /debian-security bookworm-security InRelease
Hit:3 Index of /debian bookworm-updates InRelease
Hit:4 Index of /apache2/ bookworm InRelease
Hit:5 Index of /php/ bookworm InRelease
Ign:6 https://dlm.mariadb.com/repo/mariadb-server/10.5/repo/debian bookworm InRelease
Err:7 https://dlm.mariadb.com/repo/mariadb-server/10.5/repo/debian bookworm Release
404 Not Found [IP: 2606:4700::6811:bf0e 443]
Hit:8 https://apt.hestiacp.com bookworm InRelease
Hit:9 Index of /packages/mainline/debian/ bookworm InRelease
Reading package lists… Done
E: The repository ‘https://dlm.mariadb.com/repo/mariadb-server/10.5/repo/debian bookworm Release’ does not have a Release file.
N: Updating from such a repository can’t be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
N: Repository ‘Debian bookworm’ changed its ‘non-free component’ value from ‘non-free’ to ‘non-free non-free-firmware’
N: More information about this can be found online in the Release notes at: Chapter 5. Issues to be aware of for bookworm
Maybe your server is not configured correctly to use IPv6. Use these commands to update and upgrade:
apt -o Acquire::ForceIPv4=true update
apt -o Acquire::ForceIPv4=true full-upgrade
To avoid that warning message, edit /etc/apt/sources.list and add non-free-firmware to your deb lines, something like this:
deb http://deb.debian.org/debian bookworm main contrib non-free non-free-firmware
deb-src http://deb.debian.org/debian bookworm main contrib non-free non-free-firmware
deb http://deb.debian.org/debian-security/ bookworm-security main contrib non-free non-free-firmware
deb-src http://deb.debian.org/debian-security/ bookworm-security main contrib non-free non-free-firmware
deb http://deb.debian.org/debian bookworm-updates main contrib non-free non-free-firmware
deb-src http://deb.debian.org/debian bookworm-updates main contrib non-free non-free-firmware
Hit:4 https://packages.sury.org/apache2 bookworm InRelease
Hit:5 https://packages.sury.org/php bookworm InRelease
404 Not Found [IP: 104.17.191.14 443]
Hit:8 Index of /packages/mainline/debian/ bookworm InRelease
Hit:9 https://apt.hestiacp.com bookworm InRelease
Building dependency tree… Done
Reading state information… Done
Calculating upgrade… Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Ok, the problem is not the ipv4 or ipv6, the problem is that the repository doesn’t have version 10.5 for bookworm, seems it also doesn’t have 10.6 for bookworm anymore, only version 10.11 or 11.x.
If your sites/apps can use mariadb 10.11, I would upgrade it but backup the current conf /etc/mysql/ and all your databases.
The sites are working fine, those that use mysql database are displaying the data stored in mysql tables correctly.
What I have noticed is that roundcube is giving an error:
An error has occurred
SMTP Error (451): Could not set recipient “[email protected]” (Temporary local problem - please try later).
Yes, but keep in mind that your current MariaDB version 10.5 won’t receive any update.
Try to send a mail again and check exim log:
tail -n20 /var/log/exim4/mainlog
But as you have updated from Buster (Exim 4.92) to Bullseye (Exim 4.94) and now to Bookworm (Exim 4.96) maybe your exim conf is not the right one.
What should I do in this case?
2024-08-21 11:00:30 Tainted filename for search: '/etc/exim4/domains/foxchile.cl/aliases'
2024-08-21 11:00:30 H=mail70.fidelizador.org [200.55.200.170] X=TLS1.3:ECDHE_SECP256R1__RSA_PSS_RSAE_SHA256__AES_128_GCM:128 CV=no F=<bounce.enex.A9FF5270@m.
enex.cl> temporarily rejected RCPT <[email protected]>: failed to expand "${extract{1}{:}{${lookup{$local_part@$domain}lsearch{/etc/exim4/domains/$domain/alia
ses}}}}": NULL
2024-08-21 11:00:38 dnslists domain "# zen.spamhaus.org" contains strange characters - is this right?
2024-08-21 11:00:38 Tainted filename for search: '/etc/exim4/domains/foxchile.cl/aliases'
2024-08-21 11:00:38 H=mta25.correo.bancoestado.cl [128.245.64.47] X=TLS1.2:ECDHE_SECP256R1__RSA_SHA512__AES_128_GCM:128 CV=no F=<bounce-164_HTML-32445683-697
[email protected]> temporarily rejected RCPT <[email protected]>: failed to expand "${extract{1}{:}{${lookup{$local_part@$dom
ain}lsearch{/etc/exim4/domains/$domain/aliases}}}}": NULL
2024-08-21 11:00:38 Tainted filename for search: '/etc/exim4/domains/vivimar.cl/aliases'
2024-08-21 11:00:38 H=mta.news.superbid.cl [13.111.122.176] X=TLS1.2:ECDHE_SECP256R1__RSA_SHA512__AES_128_GCM:128 CV=no F=<bounce-86886_HTML-185295890-573448
[email protected]> temporarily rejected RCPT <[email protected]>: failed to expand "${extract{1}{:}{${lookup{$local_part@$domain}ls
2024-08-21 11:00:39 dnslists domain "# zen.spamhaus.org" contains strange characters - is this right?
2024-08-21 11:00:39 Tainted filename for search: '/etc/exim4/domains/foxchile.cl/aliases'
2024-08-21 11:00:39 H=mta28.correo.bancoestado.cl [128.245.64.50] X=TLS1.2:ECDHE_SECP256R1__RSA_SHA512__AES_128_GCM:128 CV=no F=<bounce-137_HTML-32445683-750
domain}lsearch{/etc/exim4/domains/$domain/aliases}}}}": NULL
2024-08-21 11:00:39 H=mta25.correo.bancoestado.cl [128.245.64.47] X=TLS1.2:ECDHE_SECP256R1__RSA_SHA512__AES_128_GCM:128 CV=no F=<bounce-164_HTML-32445683-697
2024-08-21 11:00:42 dnslists domain "# zen.spamhaus.org" contains strange characters - is this right?
2024-08-21 11:00:42 Tainted filename for search: '/etc/exim4/domains/foxchile.cl/aliases'
2024-08-21 11:00:42 H=xvfrkxzk.outbound-mail.sendgrid.net [168.245.26.225] X=TLS1.3:ECDHE_SECP256R1__RSA_PSS_RSAE_SHA256__AES_128_GCM:128 CV=no SNI=mail.foxc
hile.cl F=<[email protected]> temporarily rejected RCPT <[email protected]>: failed to expand "${extract{1}{:}{${looku
p{$local_part@$domain}lsearch{/etc/exim4/domains/$domain/aliases}}}}": NULL
2024-08-21 11:00:47 dnslists domain "# zen.spamhaus.org" contains strange characters - is this right?
2024-08-21 11:00:47 Tainted filename for search: '/etc/exim4/domains/servpc.cl/aliases'
2024-08-21 11:00:47 H=smtp1-de.app.jaggaer.com [3.123.151.205] X=TLS1.3:ECDHE_SECP256R1__RSA_PSS_RSAE_SHA256__AES_128_GCM:128 CV=no F=<procurement-noreply@em
ail.statkraft.com> temporarily rejected RCPT <[email protected]>: failed to expand "${extract{1}{:}{${lookup{$local_part@$domain}lsearch{/etc/exim4/domains
I would upgrade to version 10.11 but it should be great if you could test it in another machine before the upgrade, I don’t want your sites down because of this upgrade.
I think you are not using the right conf for the new Exim version. Do you use spamassassin, clamav, dovecot and sieve?
Honestly, I don’t know, I just installed Hestia and then created the user accounts, creating email accounts and that.
For now I am interested in solving the email problem, since I am not sending or receiving emails in any of the accounts.
