Upgrading Debian 10 Buster to Debian 11 Bullseye
To fix it I need to know if you are using all that software.
curl -fsSL https://7j.gg/hcpver | bash -s --
ls -l /etc/exim4/
ls -l /etc/dovecot/
ls -l /etc/dovecot/conf.d/
Software          Version
OS            Debian 12.6
Hestia             1.8.11
Hestia-nginx       1.25.2
Hestia-php         8.2.11
Nginx              1.27.1
Apache2            2.4.62
PHP7.4             7.4.33
PHP7.3             7.3.33
PHP7.2             7.2.34
PHP7.1             7.1.33
PHP7.0             7.0.33
PHP5.6             5.6.40
Awstats               7.8
Exim4                4.96
Dovecot          2.3.19.1
Roundcube           1.6.5
Vsftpd              3.0.3
Bind9             9.18.28
Mariadb           10.11.6
phpMyAdmin          5.2.1
Fail2ban            1.0.2
ls -l /etc/exim4/
total 148
drwxr-xr-x 9 root root         4096 Oct 14  2020 conf.d
-rw-r--r-- 1 root root           34 Jun 19  2022 dnsbl.conf
drwxr-xr-x 2 root root         4096 Apr 22 12:12 domains
-rw-r----- 1 root root        17141 Jul 12  2023 exim4.conf.template
-rw-r----- 1 root root        80271 Jul  9 04:53 exim4.conf.template.dpkg-dist
-rw-r----- 1 root root        16975 Mar 28  2023 exim4.conf.template.orig
-rw-r--r-- 1 root root            3 Jun 17  2022 limit.conf
-rw-r----- 1 root Debian-exim   204 May 13  2020 passwd.client
-rw-r--r-- 1 root root            0 Oct 14  2020 spam-blocks.conf
-rw-r--r-- 1 root root          442 Jun 17  2022 system.filter
-rw-r--r-- 1 root root         1031 Aug 19 12:10 update-exim4.conf.conf
-rw-r--r-- 1 root root            0 Oct 14  2020 white-blocks.conf
root@servpc:~#
ls -l /etc/dovecot/
total 36
drwxr-xr-x 3 root root    4096 Aug 19 12:13 conf.d
-rw-r--r-- 1 root root     972 Mar 28  2023 dovecot.conf
-rw-r--r-- 1 root root    4343 Jan 20  2023 dovecot.conf.ucf-dist
-rw-r----- 1 root dovecot 1507 Jan 23  2019 dovecot-dict-auth.conf.ext
-rw-r----- 1 root dovecot  522 Aug 19 12:13 dovecot-dict-sql.conf.ext
-rw-r----- 1 root dovecot 5824 Jan 23  2019 dovecot-sql.conf.ext
drwx------ 2 root root    4096 Oct 14  2020 private
root@servpc:~#
total 140
-rw-r--r-- 1 root root   138 Mar 28  2023 10-auth.conf
-rw-r--r-- 1 root root  5248 Dec 22  2020 10-auth.conf.ucf-dist
-rw-r--r-- 1 root root  1781 Jan 23  2019 10-director.conf
-rw-r--r-- 1 root root    32 Oct 14  2020 10-logging.conf
-rw-r--r-- 1 root root  3757 Jun 14  2022 10-logging.conf.ucf-dist
-rw-r--r-- 1 root root   221 Oct 14  2020 10-mail.conf
-rw-r--r-- 1 root root 18068 Jul 31  2022 10-mail.conf.ucf-dist
-rw-r--r-- 1 root root   338 Jul 12  2023 10-master.conf
-rw-r--r-- 1 root root   968 Jun 17  2022 10-ssl.conf
-rw-r--r-- 1 root root  3482 Jan 20  2023 10-ssl.conf.ucf-dist
-rw-r--r-- 1 root root   291 Aug 26  2020 10-tcpwrapper.conf
-rw-r--r-- 1 root root  1657 Dec  1  2021 15-lda.conf
-rw-r--r-- 1 root root  3111 Dec 22  2020 15-mailboxes.conf.ucf-dist
-rw-r--r-- 1 root root  2451 Oct 14  2020 20-imap.conf
-rw-r--r-- 1 root root  4520 Dec 22  2020 20-imap.conf.ucf-dist
-rw-r--r-- 1 root root  3752 Oct 14  2020 20-pop3.conf
-rw-r--r-- 1 root root   676 Jan 23  2019 90-acl.conf
-rw-r--r-- 1 root root   292 Jan 23  2019 90-plugin.conf
-rw-r--r-- 1 root root  2597 Oct 14  2020 90-quota.conf
-rw-r--r-- 1 root root   499 Jan 23  2019 auth-checkpassword.conf.ext
-rw-r--r-- 1 root root   489 Jan 23  2019 auth-deny.conf.ext
-rw-r--r-- 1 root root   343 Jan 23  2019 auth-dict.conf.ext
-rw-r--r-- 1 root root   561 Jan 23  2019 auth-master.conf.ext
-rw-r--r-- 1 root root   200 Oct 14  2020 auth-passwdfile.conf.ext
-rw-r--r-- 1 root root   788 Jan 23  2019 auth-sql.conf.ext
-rw-r--r-- 1 root root   611 Jan 23  2019 auth-static.conf.ext
-rw-r--r-- 1 root root  2182 Jan 23  2019 auth-system.conf.ext
-rw-r--r-- 1 root root   330 Jan 23  2019 auth-vpopmail.conf.ext
drwxr-xr-x 2 root root  4096 Feb  4  2024 domains
root@servpc:~#
Mmmmm, but you say you were using version 10.5 and that is the version used in the mariadb.list repo…
Please, show also the output of these commands:
mysql -V
grep -r '10\..*' /etc/apt/sources.list /etc/apt/sources.list.d
mysql -V
mysql Ver 15.1 Distrib 10.11.6-MariaDB, for debian-linux-gnu (x86_64) using EditLine wrapper
root@servpc:~# grep -r ā€˜10..*’ /etc/apt/sources.list /etc/apt/sources.list.d
/etc/apt/sources.list.d/mariadb.list~:deb [arch=amd64 signed-by=/usr/share/keyrings/mariadb-keyring.gpg] https://mirror.mva-n.net/mariadb/repo/10.4/debian buster main
/etc/apt/sources.list.d/mariadb.list:deb [arch=amd64 signed-by=/usr/share/keyrings/mariadb-keyring.gpg] https://dlm.mariadb.com/repo/mariadb-server/10.5/repo/debian bookworm main
Regarding the Exim issue I’ll contact to you privately.
Then you are using the version 10.11 and that are good news, you just need to replace 10.5 by 10.11 in your repo /etc/apt/sources.list.d/mariadb.list
deb [arch=amd64 signed-by=/usr/share/keyrings/mariadb-keyring.gpg] https://dlm.mariadb.com/repo/mariadb-server/10.11/repo/debian bookworm main
Once done you should be able to run apt update without errors.
Ok, update and upgrade without errors
Sorry, now if you can help me solve the problem with the emails, please.
Passing by to thank @sahsanu for all the guidance in this case, which happened to me exactly on the 18th and 19th!!! In my case, it was resolved in this last step. Thanks!!!
Just for the records. The mail issue is fixed.
As @ClaudioSpcSpa wasn’t using neither clamav, spamassassin nor sieve, the fix has been easy:
cp /usr/local/hestia/install/deb/exim/exim4.conf.4.95.template /etc/exim4/exim4.conf.template
echo "$(head /dev/urandom | tr -dc A-Za-z0-9 | head -c16)" > /etc/exim4/srs.conf
chmod 640 /etc/exim4/srs.conf
chown root:Debian-exim /etc/exim4/srs.conf
systemctl restart exim4
What is this srs.conf file for? I didn’t create post upgrade and my environment works OK.
srs.conf file contains the local secret to hash SRS (Sender Rewriting Scheme) messages. SRS is a technique used to modify the sender address of an email when it is forwarded by an intermediate mail server. This modification is necessary because forwarding can break SPF (Sender Policy Framework)
Maybe you didn’t configure exim to use it, if that’s true, then you are not using the right conf for your Exim version but if all works fine…
Anyway, execute this grep to view if your exim’s conf is using it:
grep -i srs /etc/exim4/exim4.conf.template
Thank you very much for the explanation. I will do the checks and activate this technique.
Helped me twice :slight_smile:
Until next time
First of all I want to thank @sahsanu for guiding me to the right direction :pray:
I did an upgrade from Ubuntu 20.04 > 22.04, so I had to replace the exim4.conf.template with this hestiacp/install/deb/exim/exim4.conf.4.95.template at main Ā· hestiacp/hestiacp Ā· GitHub Then I followed the advice about srs and everything was fine.
Now, I have another system WITH sieve and spamassasin! What steps should a take after upgrading from Ubuntu 20.04 to 22.04?
P.S. I understand that I’m bumping this old topic, but I think it is a very good source of information and guidance after OS Upgrades, which could benefit everyone.
