Hello
How can I increase the maximum upload size in Wordpress?
Hello
Adjust the php.ini you’ll find in /etc/php/x.x/fpm/conf.d or similar. Replace x.x with the used version.
ITry writing the following to the file:
upload_max_filesize = 500M
post_max_size = 1000M
memory_limit = 2000M
And it didn’t work.
https://host.yourhestiapanel.com/edit/server/php/
edit the following values:
Restart service afterwards and clear all caches (incl. browser).
I get this error:
Please disable any plugins/add-ons inside your browser or contact your system administrator. If you are the system administrator you can run v-change-sys-config-value ‘POLICY_CSRF_STRICTNESS’ ‘0’ as root to disable this check.
If you followed a bookmark or an static link
