English:
Issue with reverse proxy in HestiaCP v1.8.12 (Debian 12.7)
Hello everyone,
I’m having trouble with reverse proxying in Nginx for the domain crm.idired.com . Here’s what I have tried so far, without success:
Set up custom templates (.tpl and .stpl), with and without SSL.
Checked Nginx logs for errors related to Let’s Encrypt files.
Tried redirecting traffic to the backend at 192.168.10.30:8069, with and without /web.
Reloaded Hestia and Nginx multiple times, no success.
Verified backend connectivity (curl works fine).
The configuration still returns a 404 error.
.stpl file:
server {
listen %ip%:%web_ssl_port%;
ssl on;
ssl_certificate %ssl_pem%;
location / {
proxy_set_header X-Forwarded-Port "443";
proxy_set_header X-Forwarded-Proto "https";
proxy_pass http://192.168.10.30:8069;
proxy_redirect http:// https://;
include %home%/%user%/conf/web/snginx.%domain%.conf*;
.tpl file:
server {
listen %ip%:%web_port%;
location / {
rewrite ^(.*) https://%domain_idn%$1 permanent;
include %home%/%user%/conf/web/*nginx.%domain_idn%.conf_letsencrypt;
Español:
Problema con proxy inverso en HestiaCP v1.8.12 (Debian 12.7)
Hola a todos,
Estoy teniendo problemas con el proxy inverso en Nginx para el dominio crm.idired.com . He intentado lo siguiente sin éxito:
Configurar plantillas personalizadas (.tpl y .stpl), con y sin SSL.
Comprobé los logs de Nginx, verificando errores relacionados con archivos de Let’s Encrypt.
Probé redirigir el tráfico al backend 192.168.10.30:8069, con y sin /web al final.
Recargué Hestia y Nginx varias veces sin éxito.
Verifiqué la conectividad con el backend (curl funciona correctamente).
La configuración sigue devolviendo un error 404. Agradecería cualquier ayuda o sugerencia para resolver esto.
Archivo .stpl:
server {
ssl on;
location / {
Archivo .tpl:
server {
location / {
Why? if you want to use https to connect to backend just do it on`
That’s wrong, in stpl template use this:
In tpl template use this include:
So then I would have to go?
.stpl file:
server {
ssl on;
location / {
.tpl file:
server {
location / {
Error: nginx restart failed
Regarding include directives, yes.
Did you rebuild your web domain after modifying templates?
Also, did you check why nginx didn’t restart?
Yes
root@srv1:~# systemctl status nginx --no-pager -l
Loaded: loaded (/lib/systemd/system/nginx.service; enabled; preset: enabled)
Active: active (running) since Fri 2024-10-04 23:08:34 CEST; 35min ago
Docs: nginx documentation
Process: 611 ExecStart=/usr/sbin/nginx -c /etc/nginx/nginx.conf (code=exited, status=0/SUCCESS)
Process: 11450 ExecReload=/bin/sh -c /bin/kill -s HUP $(/bin/cat /var/run/nginx.pid) (code=exited, status=0/SUCCESS)
Main PID: 2005 (nginx)
Tasks: 6 (limit: 28784)
Memory: 63.7M
CPU: 4.891s
CGroup: /system.slice/nginx.service
├─ 2005 “nginx: master process /usr/sbin/nginx -c /etc/nginx/nginx.conf”
├─11728 “nginx: worker process”
├─11729 “nginx: worker process”
├─11730 “nginx: worker process”
├─11731 “nginx: worker process”
└─11732 “nginx: cache manager process”
Oct 04 23:08:32 srv1.dns-idired.com systemd[1]: Starting nginx.service - nginx - high performance web server…
Oct 04 23:08:34 srv1.dns-idired.com systemd[1]: Started nginx.service - nginx - high performance web server.
Oct 04 23:35:10 srv1.dns-idired.com systemd[1]: Reloading nginx.service - nginx - high performance web server…
Oct 04 23:35:10 srv1.dns-idired.com systemd[1]: Reloaded nginx.service - nginx - high performance web server.
Oct 04 23:36:14 srv1.dns-idired.com systemd[1]: Reloading nginx.service - nginx - high performance web server…
Oct 04 23:36:14 srv1.dns-idired.com systemd[1]: Reloaded nginx.service - nginx - high performance web server.
Oct 04 23:36:29 srv1.dns-idired.com systemd[1]: Reloading nginx.service - nginx - high performance web server…
Oct 04 23:36:29 srv1.dns-idired.com systemd[1]: Reloaded nginx.service - nginx - high performance web server.
I get the We’re working on it! window.
This site is currently under construction.
Please check back soon.
nginx is working fine, I don’t know the reason for the restart error,
nginx -t
cat /home/*/conf/web/crm.idired.com/nginx.ssl.conf
root@srv1:~# nginx -t
nginx: [warn] protocol options redefined for 10.8.0.2:443 in /etc/nginx/conf.d/domains/crm.idired.com.ssl.conf:2
nginx: [emerg] unknown directive "ssl" in /etc/nginx/conf.d/domains/crm.idired.com.ssl.conf:5
nginx: configuration file /etc/nginx/nginx.conf test failed
server {
listen 10.8.0.2:443;
server_name crm.idired.com ;
ssl on;
ssl_certificate /home/idired.com/conf/web/crm.idired.com/ssl/crm.idired.com.pem;
ssl_certificate_key /home/idired.com/conf/web/crm.idired.com/ssl/crm.idired.com.key;
location / {
proxy_pass https://192.168.10.30:8069;
include /home/idired.com/conf/web/crm.idired.com/nginx.ssl.conf_*;
Modify stpl like this:
server {
listen %ip%:%web_ssl_port% ssl;
location / {
Thank you very much, it worked for me.
I’ll save it and see where the error is. Thank you very much.
system
Closed
November 3, 2024, 10:01pm
11
