floown
January 28, 2021, 8:14am
1
With a default HestiaCP installation, I have this message in a fresh install of Drupal 9:
Your server can’t display the progress of file transfers. This requires that PHP is executed with mod_php or PHP-FPM and not FastCGI.
What do I need to change in my conf files to use PHP-FPM? (I have googled)
floown
January 28, 2021, 12:15pm
3
I have install the server and HestiaCP just several month ago, in summer last year I think. It’s a Ubuntu 20.04.
//EDIT : the 15th august 2020
eris
January 28, 2021, 12:57pm
4
Then is should install by default with php-fpm enabled.
Run first:
And then
#!/bin/bash
# This script migrates your apache2 installation form mod_prefork to mpm_event.
# Includes
source $HESTIA/conf/hestia.conf
# Check if apache2 is in use
if [ "$WEB_SYSTEM" != "apache2" ]; then
echo "Apache2 isn't installed on your system, canceling migration..." && exit 1
fi
# Check if PHP-FPM is instaled
if [ "$WEB_BACKEND" != "php-fpm" ]; then
echo "PHP-FPM not yet installed please run migrate_apache.sh first" && exit 1
fi
# Check if mod_event is already enabled
if [ $(a2query -M) = 'event' ]; then
echo "mod_event is already enabled, canceling migration..." && exit 1
This file has been truncated. show original
floown
January 28, 2021, 1:29pm
5
# locate migrate_apache.sh
/usr/local/hestia/install/upgrade/manual/migrate_apache.sh
# /usr/local/hestia/install/upgrade/manual/migrate_apache.sh
# locate migrate_mpm_event.sh
/usr/local/hestia/install/upgrade/manual/migrate_mpm_event.sh
# /usr/local/hestia/install/upgrade/manual/migrate_mpm_event.sh
My version is:
Hestia Control Panel:
v1.3.2
eris
January 28, 2021, 1:34pm
6
Then PHP-FPM should be enabled. You should also get now an option to select you php version
floown
January 28, 2021, 1:54pm
7
See my screencaps here: The templates for Drupal 8 (or 9) aren't listed in GUI
I don’t know why I have this output un Drupal dashboard:
mod-fcgid?
apachectl -M
Loaded Modules:
core_module (static)
so_module (static)
watchdog_module (static)
http_module (static)
log_config_module (static)
logio_module (static)
version_module (static)
unixd_module (static)
access_compat_module (shared)
actions_module (shared)
alias_module (shared)
auth_basic_module (shared)
authn_core_module (shared)
authn_file_module (shared)
authz_core_module (shared)
authz_host_module (shared)
authz_user_module (shared)
autoindex_module (shared)
deflate_module (shared)
dir_module (shared)
env_module (shared)
fcgid_module (shared)
filter_module (shared)
status_module (shared)
mime_module (shared)
mpm_event_module (shared)
negotiation_module (shared)
proxy_module (shared)
proxy_fcgi_module (shared)
remoteip_module (shared)
reqtimeout_module (shared)
rewrite_module (shared)
rpaf_module (shared)
setenvif_module (shared)
socache_shmcb_module (shared)
ssl_module (shared)
suexec_module (shared)
eris
January 28, 2021, 2:11pm
8
You are using Apache2 + Nginx instead of Nginx as stand alone.
If php-fpm is enabled you should be able to pick the templates for PHP
floown
January 28, 2021, 2:27pm
9
dpkg -l -fpm | grep ii
ii php7.3-fpm 7.3.26-1+ubuntu20.04.1+deb.sury.org+1 amd64 server-side, HTML-embedded scripting language (FPM-CGI binary)
ii php7.4-fpm 7.4.14-1+ubuntu20.04.1+deb.sury.org+1 amd64 server-side, HTML-embedded scripting language (FPM-CGI binary)
jayden
January 12, 2024, 2:36pm
10
Hi
I have the same problem.
Hestia : v1.8.11
Fresh install (bash hst-install.sh)
No Customization
But,
Drupal shows me that my server uses “mod-fcgid” instead of “php-fpm”.
Nothing changed even if I change it to default or PHP-8_2 at domain Backend Template PHP-FPM settings.
Any idea, please ?
