Using without a port?
how can I setup the panel so that I can use it without specifying the port ?
My main domain has SSL and Hestia installs cert when installing the panel. In the config before installation I tried putting 443 as port instead of 8083. Should I put port 80 ?
panel.example.ltd instead of panel.example.ltd:port
You can’t use port 80 or 443 as it is allready occupied by Nginx
and
so I should edit it to be like this in /usr/local/hestia/nginx/conf/nginx.conf ?
Copy the templates to /usr/local/hestia/data/templates/web/nginx/
And enable it for the domain you want it to be active…
Sorry for asking but how exactly do I enable it for the domain ?
Select under Advanced Options → Proxy template “cp”
Yes I have found it. I havent seen that you have sent link in the previous message. But as I can see it does not work unfortunately. Do I need to rebuild it ?
Copy both:
and web-templates/cp.tpl at master · jaapmarcus/web-templates · GitHub
and select it from the same list…
I did.
I added both files to : /usr/local/hestia/data/templates/web/nginx/
And then on the panel selected the domain → advanced options → proxy template → cp. Saved but it did not work.
What is the error?
Site loads quite long and then I get this.
Internal Server Error
Oops! Something went wrong.
The server encountered an internal error or misconfiguration and was unable to complete your request.
Error Code: 500
Did you change the Hestia port?
Run v-change-sys-port 8083 to reset it to the default or update the port number in the templates
I didnt change the port, tried the command and restarted the service. Still no luck
Check /var/log/apache2/domains/domain.error.log what the issue is…
Unable to connect to the upstream…
Its ok I fixed it. Thank you for your help, much appreciated
One more question. How could I put it behind a cloudflare proxy so that I can use it without a port ?
i am trying to do the same thing but i want to do a bit more research before i screw up my perfectly working setup.
i am behind cloudflare so i am using port 2087 instead of 8083, is it possible to modify this file add it in template and get it working on just domain with cloudflare behind?
Note: had to change port because cloudflare blocks 8083
Update, i have managed to get my main HCP directly without port, but when i try other domains they dont work, i am using cloudflare proxy as well and using cname records.
UPDATE:All domains working including their hcp with ssl and no port needed :slight_smile: thanks everyone for their support
