/usr/sbin/sendmail issue on update of OS-Release
I updated my version of Ubuntu and during the update, I have now lost the ability to use either rainloop or snappymail, as I ran the update command for Hestia its saying /usr/sbin/sendmail is not found.
Is there a place that I can download the configuration for that directory to fix it, if not how do I go about fixing it without reinstalling as there is client information which cant be lost (even though its backed up)
hi reinstall the sendmail :
apt --reinstall install sendmail sendmail-cf m4
or install if missing :
apt install sendmail sendmail-cf m4
Thanks this worked.
I also had to sort out my sources.list as apparently that was blank.
