V-add-domain with indicating template
Hello
I have a script which setup on server
‘sudo /usr/local/hestia/bin/v-add-domain user “{domain}” “{IP}”’,
‘sudo /usr/local/hestia/bin/v-add-web-domain-redirect user “{domain}” “{domain}” 301’,
‘sudo /usr/local/hestia/bin/v-add-letsencrypt-domain user “{domain}” “www.{domain}”’,
‘sudo /usr/local/hestia/bin/v-add-web-domain-ssl-hsts user “{domain}”’,
‘sudo /usr/local/hestia/bin/v-add-web-domain-ssl-force user “{domain}”’
and I have a custom nginx template which i want to be implemented.
Can I do it somehow via CLI with these binaries? Is it possible?
Yes.
If you are using only Nginx:
v-change-web-domain-tpl USER DOMAIN TEMPLATE [RESTART]
If you are using Nginx + Apache2 and you want to change the Nginx template:
v-change-web-domain-proxy-tpl USER DOMAIN TEMPLATE [EXTENTIONS] [RESTART]
can I do it via v-add-domain ?
No, v-add-domain doesn’t accept a template name as an argument, nor does v-add-web-domain.
