When I add a new IP and restart the container, the Apache2, Nginx and Network services do not work.
After many tests and research I found out what the problem is but I don’t know how to fix it correctly.
Important this happens because I am using a Debian in a proxomox LXC container with OVH floating IPs
I am using Debian and in Debian in /etc/network/interfaces the Hestia IPs with the v-add-sys-ip command are created like this:
iface eth0 inet static
address 123.123.123.123
netmask 255.255.255.255
auto eth0
address 124.124.124.124
auto eth0
The mistake is that they should go with an increased number like this:
iface eth0:1 inet static
auto eth0:1
iface eth0:2 inet static
auto eth0:2
missing in front of hip iface eth0 los :1 :2 :3 etc.
