egorka
1
Every day at about 5:10 (the v-backup-users job time in the cron), I have a load jump on the server.
At the same time, backups in the server settings are disabled.
v-backup-users - this is the backup task, why does it work?
In Vesta, this setting definitely turned off backups. I even wrote it on the forum once Удаление бэкапов из панели - Vesta Control Panel - Forum
eris
2
Local backup no should not disable backup overall as a 3rd party (sftp, ftp) could still be set…
There is a check https://github.com/hestiacp/hestiacp/blob/681bfdbafd8c734086896119738734409200f663/func/main.sh#L200-L206
You can disable the backups by updating your package and set the number to 0 this will disable the creation of backups
egorka
3
I turned off backup - you can see this in the screenshot in the first message. But it still works every day.
egorka
4
What third-party backups can you recommend? I used R1 Soft, but the last time its ISO couldn’t load the server ;(
egorka
5
I paused this task. This is an ugly solution, since I already disabled backups in the settings. But they continued to be executed.
falzo
6
Just disable the cronjob and be done, no?
egorka
7
Yes
I mean that at first I disabled backup in options) and it continued to work
