/var/cache/nginx/micro//0/f6/failed
Hello everyone, perhaps someone has encountered such a misfortune. I enabled the FastCGI cache, installed the plugin Hestia Nginx Cache and configured. Everything is fine, but it is full of errors. I see this in log. Standard installation Nginx+PHP+Mariabd. As I can see, the bots are looking for the file and do not find it, the result of the error, but perhaps I am missing something?
I don’t remember this before, I was enabling the cache on another instance and now I’ve disabled CF and enabled FastCGI and errors are pouring. As I can see, they are looking for a sitemap, if you take https://quantumtransition.angellive.ru/sitemap.xml it is available.
/var/log/nginx. The most interesting thing is that on another site, with the same plugins and settings, there is no such thing https://opensource.angellive.ru/
2024/09/18 23:34:11 [crit] 587809#587809: unlink() "/var/cache/nginx/micro/quantumtransition.angellive.ru/0/f6/c2f5d180508b07951b901b0b5b1a7f60" failed (2: No such file or directory)
2024/09/18 23:58:28 [crit] 587809#587809: unlink() "/var/cache/nginx/micro/quantumtransition.angellive.ru/c/c8/b37ed0af04e8d9a3a04b3fab95731c8c" failed (2: No such file or directory)
2024/09/20 06:53:29 [crit] 758509#758509: unlink() "/var/cache/nginx/micro/quantumtransition.angellive.ru/0/2d/a3a5e8470003284522ea703d796302d0" failed (2: No such file or directory)
2024/09/20 06:54:30 [crit] 758509#758509: unlink() "/var/cache/nginx/micro/quantumtransition.angellive.ru/3/4d/22a15cd6d9df3d9e91f1d668bdd2e4d3" failed (2: No such file or directory)
2024/09/20 07:05:43 [crit] 758509#758509: unlink() "/var/cache/nginx/micro/quantumtransition.angellive.ru/7/c1/f8d86cae9ff44811d0b84b259cafbc17" failed (2: No such file or directory)
2024/09/20 07:13:52 [crit] 758509#758509: unlink() "/var/cache/nginx/micro/quantumtransition.angellive.ru/e/75/b96de41676eb9088232ff305f0ac575e" failed (2: No such file or directory)
2024/09/20 07:15:47 [crit] 758509#758509: unlink() "/var/cache/nginx/micro/quantumtransition.angellive.ru/5/65/6a8fe2c040d38c61188107e285b46655" failed (2: No such file or directory)
2024/09/20 07:15:55 [crit] 758509#758509: unlink() "/var/cache/nginx/micro/quantumtransition.angellive.ru/6/54/e2dd05fd68ba5689562af4832b7ea546" failed (2: No such file or directory)
/var/log/nginx/domains/quantumtransition.angellive.ru.error.log
2024/09/19 09:52:14 [crit] 600609#600609: *23556 chmod() "/var/cache/nginx/micro/quantumtransition.angellive.ru/2/8c/5997b3b0fe4bf0f8b67c54af7f2e88c2.0000001064" failed (2: No such file or directory) while reading upstream, client: 52.167.144.140, server: quantumtransition.angellive.ru, request: "GET /sitemap.xml HTTP/2.0", upstream: "fastcgi://unix:/run/php/php8.2-fpm-quantumtransition.angellive.ru.sock:", host: "quantumtransition.angellive.ru"
2024/09/19 09:52:14 [crit] 600609#600609: *23556 unlink() "/var/cache/nginx/micro/quantumtransition.angellive.ru/2/8c/5997b3b0fe4bf0f8b67c54af7f2e88c2.0000001064" failed (2: No such file or directory) while reading upstream, client: 52.167.144.140, server: quantumtransition.angellive.ru, request: "GET /sitemap.xml HTTP/2.0", upstream: "fastcgi://unix:/run/php/php8.2-fpm-quantumtransition.angellive.ru.sock:", host: "quantumtransition.angellive.ru"
2024/09/20 06:47:59 [crit] 730726#730726: *25967 chmod() "/var/cache/nginx/micro/quantumtransition.angellive.ru/2/8c/5997b3b0fe4bf0f8b67c54af7f2e88c2.0000001543" failed (2: No such file or directory) while reading upstream, client: 40.77.167.19, server: quantumtransition.angellive.ru, request: "GET /sitemap.xml HTTP/2.0", upstream: "fastcgi://unix:/run/php/php8.2-fpm-quantumtransition.angellive.ru.sock:", host: "quantumtransition.angellive.ru"
2024/09/20 06:47:59 [crit] 730726#730726: *25967 unlink() "/var/cache/nginx/micro/quantumtransition.angellive.ru/2/8c/5997b3b0fe4bf0f8b67c54af7f2e88c2.0000001543" failed (2: No such file or directory) while reading upstream, client: 40.77.167.19, server: quantumtransition.angellive.ru, request: "GET /sitemap.xml HTTP/2.0", upstream: "fastcgi://unix:/run/php/php8.2-fpm-quantumtransition.angellive.ru.sock:", host: "quantumtransition.angellive.ru"
Hello everyone, continues to pour errors, I reinstalled the system, from Debian 12 to Ubuntu 22.04, the errors have changed, they are no longer tied to the site, but there are dozens of them per day. I believe the bots are looking for something and this is a possible response to caching.
2024/10/09 00:27:40 [crit] 992#992: unlink() "/var/cache/nginx/micro/5/00/5d912b03500c55e13bbd7d82940da005" failed (2: No such file or directory)
2024/10/09 00:27:40 [crit] 992#992: unlink() "/var/cache/nginx/micro/d/98/d1152a391e56621f05a4a6549ebb298d" failed (2: No such file or directory)
2024/10/09 00:27:40 [crit] 992#992: unlink() "/var/cache/nginx/micro/7/33/cbfc23f37203703d99887fb5f20df337" failed (2: No such file or directory)
2024/10/09 00:27:40 [crit] 992#992: unlink() "/var/cache/nginx/micro/c/45/7ef6636e3161667b3c55a92eaffc145c" failed (2: No such file or directory)
2024/10/09 00:27:40 [crit] 992#992: unlink() "/var/cache/nginx/micro/c/10/27dfb5fba8e9c41f8d10f7a4f3d3b10c" failed (2: No such file or directory)
2024/10/09 00:27:40 [crit] 992#992: unlink() "/var/cache/nginx/micro/c/ca/a59231b95a8651c5520a68e1a4eadcac" failed (2: No such file or directory)
2024/10/09 00:27:40 [crit] 992#992: unlink() "/var/cache/nginx/micro/c/d4/da608e05ee1d6b579ff14abedfd60d4c" failed (2: No such file or directory)
2024/10/09 00:27:40 [crit] 992#992: unlink() "/var/cache/nginx/micro/c/c8/b37ed0af04e8d9a3a04b3fab95731c8c" failed (2: No such file or directory)
2024/10/09 00:27:40 [crit] 992#992: unlink() "/var/cache/nginx/micro/6/ee/4b3fe6624397be23a74884951bc4aee6" failed (2: No such file or directory)
2024/10/09 00:27:40 [crit] 992#992: unlink() "/var/cache/nginx/micro/6/0a/fa16d918ae4090fdc974f0ed628460a6" failed (2: No such file or directory)
2024/10/09 00:27:40 [crit] 992#992: unlink() "/var/cache/nginx/micro/6/7f/07a1656a8184294f9fecfff5755e87f6" failed (2: No such file or directory)
2024/10/09 00:27:40 [crit] 992#992: unlink() "/var/cache/nginx/micro/a/94/14a70fed8ff1251edb10fffa015f894a" failed (2: No such file or directory)
2024/10/09 00:27:40 [crit] 992#992: unlink() "/var/cache/nginx/micro/a/a8/f6d2b4fb0d031b6a81a889a9cdd53a8a" failed (2: No such file or directory)
2024/10/09 00:27:40 [crit] 992#992: unlink() "/var/cache/nginx/micro/1/52/5ce5f06bdaa86b92ffdccf77fbc50521" failed (2: No such file or directory)
2024/10/09 00:27:40 [crit] 992#992: unlink() "/var/cache/nginx/micro/1/57/7f7f5a7fe152585c306236b6dce90571" failed (2: No such file or directory)
2024/10/09 00:27:40 [crit] 992#992: unlink() "/var/cache/nginx/micro/0/95/8f9b98d52882d0344db9932ca917c950" failed (2: No such file or directory)
2024/10/09 00:27:40 [crit] 992#992: unlink() "/var/cache/nginx/micro/0/f1/2f8f42349a97a9a15f5f28b02d9aef10" failed (2: No such file or directory)
2024/10/09 00:27:40 [crit] 992#992: unlink() "/var/cache/nginx/micro/e/e0/53bc610585eea6e42af32e1cae835e0e" failed (2: No such file or directory)
2024/10/09 00:27:40 [crit] 992#992: unlink() "/var/cache/nginx/micro/8/e4/cb6aafa84df5a3061b17d4428a0e8e48" failed (2: No such file or directory)
2024/10/09 00:27:40 [crit] 992#992: unlink() "/var/cache/nginx/micro/9/21/fa5b1cee4d69cf1b23c2b0e610054219" failed (2: No such file or directory)
2024/10/09 00:27:40 [crit] 992#992: unlink() "/var/cache/nginx/micro/9/e1/f072f69e02af238ff3e06bff1b9b1e19" failed (2: No such file or directory)
2024/10/09 00:27:40 [crit] 992#992: unlink() "/var/cache/nginx/micro/2/60/dc29e59d4cfca1df1390956946e88602" failed (2: No such file or directory)
2024/10/09 00:27:40 [crit] 992#992: unlink() "/var/cache/nginx/micro/2/4c/c52edeecf4d11898e2de6eb91ff0c4c2" failed (2: No such file or directory)
2024/10/09 00:27:40 [crit] 992#992: unlink() "/var/cache/nginx/micro/b/04/08d8919bb93aca4de1f6e9f71f20404b" failed (2: No such file or directory)
2024/10/09 00:27:40 [crit] 992#992: unlink() "/var/cache/nginx/micro/b/87/8beb9404fc115c6201c85d0d4dd1f87b" failed (2: No such file or directory)
2024/10/09 00:57:40 [crit] 992#992: unlink() "/var/cache/nginx/a4/7f84e75c555af06615a5f9b374089ba4" failed (2: No such file or directory)
2024/10/09 00:57:40 [crit] 992#992: unlink() "/var/cache/nginx/a0/dd71f56a63ae0197f68bafa657d125a0" failed (2: No such file or directory)
2024/10/09 00:57:40 [crit] 992#992: unlink() "/var/cache/nginx/15/c2c916bb04533afc2f07e30581bd4b15" failed (2: No such file or directory)
2024/10/09 00:57:40 [crit] 992#992: unlink() "/var/cache/nginx/05/5d912b03500c55e13bbd7d82940da005" failed (2: No such file or directory)
2024/10/09 00:57:40 [crit] 992#992: unlink() "/var/cache/nginx/8d/d1152a391e56621f05a4a6549ebb298d" failed (2: No such file or directory)
2024/10/09 00:57:40 [crit] 992#992: unlink() "/var/cache/nginx/37/cbfc23f37203703d99887fb5f20df337" failed (2: No such file or directory)
2024/10/09 00:57:40 [crit] 992#992: unlink() "/var/cache/nginx/5c/7ef6636e3161667b3c55a92eaffc145c" failed (2: No such file or directory)
2024/10/09 00:57:40 [crit] 992#992: unlink() "/var/cache/nginx/0c/27dfb5fba8e9c41f8d10f7a4f3d3b10c" failed (2: No such file or directory)
2024/10/09 00:57:40 [crit] 992#992: unlink() "/var/cache/nginx/ac/a59231b95a8651c5520a68e1a4eadcac" failed (2: No such file or directory)
2024/10/09 00:57:40 [crit] 992#992: unlink() "/var/cache/nginx/4c/da608e05ee1d6b579ff14abedfd60d4c" failed (2: No such file or directory)
Those files are created by fastcgi but if the cache clear or invalids it deletes and creates a error nothing to care about
