Vhost.conf vhost_ssl.conf where in hestia?
vhost.conf и vhost_ssl.conf, need change fphp_admin_value open_basedir
`php_admin_value open_basedir none
to
php_admin_value open_basedir /full/path/to/dir:/full/path/to/directory/httpdocs:/tmp`
I suggest to write clear and understandable posts and/or questions, what you wrote here is not understandable.
Also probaly this one here still fits perfectly:
As ScIT mentioned. Your question is not clear.
If i remotely understand your question right, create a new template file in
/usr/local/hestia/data/templates/web/php-fpm
sory me
1. vhost.conf vhost_ssl.conf files of Apache VirtualHost Examples - Apache HTTP Server Version 2.4
right?
i think yes
2
hestiacp hawe apache?
i think yes
Question:
where vhost.conf vhost_ssl.conf files in hestiacp ?
1) yes
2) yes
Answer:
https://docs.hestiacp.com/admin_docs/server_management.html#how-do-web-templates-work
ty
ok
how i can fix error on site :
Warning: file_exists(): open_basedir restriction in effect.
File(/home/lotric/web/bill.123.ru/public_html/app//modules/billmanagervps.zip/billmanagervps.zip.php)
is not within the allowed path(s): (
/home/lotric/web/bill.123.ru/public_html:/home/lotric/web/bill.123.ru/
unrelated to hestia.
https://www.php.net/manual/en/ini.core.php#ini.open-basedir
