Hello, I have a small task with which I need help.
Given:
Hestiacp which is mounted on a virtual machine
Access to the panel itself is
A domain that is assigned to several other machines, to my virtual outside is access to the port
Hestiacp sees an external address as well as inner
Problem.
I created a domain. But on the outside the contents /var /www opens
not the content of the created domain
When I try to connect to the internal address to the virtual machine - I get the same
Is it possible to solve it somehow? I will provide additional information. Thank you very much.
