Visual templates
Hello community, I’m curious if there is a design template for hestiacp.
Cpanel and DirectAdmin have an attractive front-end design and for the end customer it seems to be more pleasant than, for example, the one currently used by Hestiacp.
Can you tell me if the panel is designed to add design templates created by us? Or to add them in case someone collaborates and can create them? Also, that in the future it can be sold on a marketplace?
Thank
Support self creation! You can refer to the document!
Only with CSS at the moment…
And there is no market place…
Look at this post as well: Max Theme for HestiaCP
