VPN use refused connection error
Hi Community.
I Installed Wireguard in a VPS where HestiaCP is installed too. The goal is to only access hestiacp by VPN.
So in HestiaCP I go to the Firewall settings and edit the rule:
[ ACCEPT] > HESTIA > TCP > 8083 > 0.0.0.0/0 to port 10.10.10.0/24. (I suppose it’s allowing all IP in this network. I also tried with 10.10.10.2/32 which is the VPN device IP).
I get the Refuse conn error when logged in by VPN.
Am i missing something? I’ve search the forum (and internet) but with no success.
Thank you.
Hi @ncm
Please show the rules you are using:
iptables -S -t nat
iptables -S
Also your net:
ip a
Hello sahsanu, thank you for your reply.
thank you
These are the commands when i tried to set and use the VPN:
Difference between the two files:
out:
-A INPUT -p tcp -m tcp --dport 8083 -j ACCEPT
in:
-A OUTPUT -d 10.13.13.2/32 -p tcp -m tcp --sport 8083 -j ACCEPT
-A fail2ban-MAIL -s 103.194.88.65/32 -j REJECT --reject-with icmp-port-unreachable
Are you sure you configured wireguard correctly? I mean, the iptables rules to do postrouting and forward. Also, I don’t see any wireguard interface…
Thank you sahsanu, the problem was related with hosts file misconfiguration.
